Does anybody know of a way to convert a pulsing signal (eg, square wave, 2v peak to peak) to a switching action (like that of relay). Well, basically, it is a relay I need, but one which can operate at somewhere up to 1mhz, and needs very little energy to energise (ie, from a 555 oscillator). I don't know if its a transistor I want, or FET or something. Any help appreciated!
Angry!? I'm absolutely electrolytic! Will have to make do with myspace now I guess... |
Generating 1MHz will be a bit much for a 555, which tops off at around 100kHz. One way is to peak-rectify the pulse, smooth to a voltage and detect when a voltage level is present. Another way is with a re-triggerable monostable.
\"You can\'t make a circuit fool-proof, cause fools are so ingenious!\" |
you could use a FET , but you would have to tweak the signal a bit..
The value of the capacitor will depend on the frequency of the pulses, and how fast you want the relay to respond. |
Oops, yeah. Well, it needs to work at around 100k then, possibly less, but much faster than a mechanical relay.
Ok, that suggestion Nigel made, how would I wire that up (schematic)? It sounds ideal. I don't know what other details I can give, but if it helps, it will only need to switch a 1.5v load. It is currently switched by mechanical contacts, so a device with an output switching that is very close to this is ideal.
Ok, well, this post is related to my other one about the counter circuit. Basically, I think I have found a counter circuit that will cost me pretty well nothing. It comes in the form of a free walkers crisps pedometer, and can count up to 19999. Inside it, there is a little pivot, which touches a contact, and every time it does so, the display advances by 1. I can't really give too many details on how it works, as the circuit is an IC sealed in resin type job. I runs off a 1.5v button cell though.
I will probably have the pulses coming from a 555 oscillator, running at 10-100k. I don't know too much about how much power comes out of one, but i'm pretty sure its a square wave. So, to make the counter for the speed measure, I need a circuit to convert the oscillator output into switching that the pedometer can count.
Yeah, that was a concern of mine. It responds to a pulse of incredibly short duration, but it may need to wait a while before it can recieve another. So, yeah, I better test that.
How about a circuit like this?
