Charging a cell phone (Android) from 12v
  1. #1
    dilbert9 dilbert9 is offline
    Hello all. I am new here and did a little searching around before deciding to post this. I am attempting to create converter that will allow me to charge my cell phone (android) from my bike (12v power). I was hoping to be able to create my own instead of just hacking apart a cigarette lighter plug.
    My first attempt was with using a 7805 regulator (bench testing with a 12v power supply). In my tests the phone would go into charge and then stop. I had my meter plugged in and was checking the amp pull and when it went into charge it was hitting 1.55A and then it would stop and my meter would go into OL (overload). Then would start up again for about half a second. I presume I am hitting a maximum with the regulator. Here is the circuit I was using for this:
    Does anyone have any suggestions as to what I can do to either the circuit or which regulator I can use to get this working?
  2. Thread Starter #2
    Looking around I found this:
    http://search.digikey.com/us/en/prod...68-5-ND/585989
    It seems like it could be what I want, but I am unsure.
    0
  3. #3
    Pommie Pommie is offline
    The 7805 is rated at 1A and is probably shutting down due to thermal overload. Try adding a heatsink and a 5Ω 5W resistor on the input to drop some voltage.
  4. Thread Starter #4
    So dropping the input voltage (the 12v supply) will lower the amperage allowed to the phone? If I can limit the phone to only 800mA I think the 7805 could work. Will adding this resistor to the input do this for me? Or is there another way to limit the current the phone can pull?
    0
  5. #5
    Menticol Menticol is offline
    I know you are talking about an Android, but with the iPod and other Apple devices you can select the charging mode just playing with the Data+ and Data- lines and some resistors
    See
    http://vimeo.com/13835359
    It seems the data lines were gradually adopted as a means for iPhones and iPods to identify the charger that had been connected. By adding voltage dividers to the D+ and D- lines you can instruct the handheld to pull 1 Amp (with data voltages of 2.8v and 2.0v) for wall chargers or 0.5 Amps (2.0v on both data lines) for portable chargers
    Can Android provide the same feature?
    0
    Felipe
    Visit my blog cocodrilabs.wordpress.com - DIY Repairs, Device Modification and Improvement.
  6. Thread Starter #6
    Quote Originally Posted by Menticol View Post
    See
    I appreciate the reply, however this is a feature of the iDevices and not Android devices. I guess this all boils down to figuring out how to limit the amount of current the phone can pull all while allowing it to pull enough to charge and not just run.
    0
Charging a Cell Phone Battery AHAB99 General Electronics Chat 10 24th March 2011, 01:03 PM
Cell phone battery charge from solar energy zedora Electronic Projects Design/Ideas/Reviews 6 14th April 2010, 11:22 AM
would charging a cell phone or aa (nicd or nimh) intermittently decrease it's life? the judge General Electronics Chat 3 24th March 2010, 07:29 PM
Cell Phone Battery Charger From Laptop Batteries roltex_rohit123 Electronic Projects Design/Ideas/Reviews 0 10th February 2010, 09:20 AM
Cell Phone Charging - Interesting Find klm General Electronics Chat 4 23rd December 2006, 07:16 AM
Page Time: 0.07471 seconds      Memory: 7,399 KB      Queries: 16      Templates: 0
