hi Neil,
Ref your PM, I have just added a circuit option for a 12V monitor on my Blog.
It uses the battery supply, no 9V regulator.
Eric
http://www.electro-tech-online.com/a...rystatusv1.gif
Hi
New to this forum, and returning to electronics as a hobby (but spent the last 15 years in electronic manufacture, until it moved to a "low Cost country"
I want to build a battery monitor unit, to be built into a model locomotive to show battery condition, and re-charge. I want the make a PCB & circuit which will work for 12v and 24v with a few component changes. The LED display will be a few green, yellow and red LEDs, to show battery condition.
I tried the circuit which Roff produced back in February 2006, on a bread baord, as this looked nice, (used a LM3914, and LM742 ot TL071 op amp, & a LM317 volt reg)
Sorry, not sure how to get a link to this.
but could not get it to work properly, then tried a few other simpler designs, using the LM3914, just to check I understood the diagrams, and that I did not damage the LM3914 chip, and these work. I am starting to understand the chip and the datasheet.
I have downloaded the LM3914 calculator, which has also helped me get my old brain working again. so have worked out the resisitor network arround pin 7&8.
I like the idea of using a voltage reference, so want to use a fixed 9V volt reg, (with a couple of caps, to cover noise etc) to drive the LED's & the LM3914.
I was think of a voltage divider to get the input to pin 5, the signal pin, at arround 4 to 5 volts, plus I guess a decoupling cap.
I think I then need to supply "V Low" (pin 4) with a voltage arround 4 volts,(bottom of the display, and this is this just a resistor and pot, to 0V to set the voltage at pin 4 to 4ish volts?
The a similar arrangement around pin 6, "V High" to set the upper point?
Does pin 6 and 7 link together?
Does this sound right?
or
Is there a better way?
Sorry, I have no way of drawing this on a computer, to show my ramblings.
Neil
hi Neil,
Eric
"Nigels Asm tutorials:" www.winpicprog.co.uk/
"Ian Rogers 'C' conversion of Nigels Asm tutorials:" http://www.electro-tech-online.com/c...torials-c.html
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Need a diagram for 24v Battery Monitor using LM3914 chip | sprat | General Electronics Chat | 25 | 24th February 2012, 07:20 AM |
| LM3914 Help - Battery Monitor Circuit Needed! | Skyone | Electronic Projects Design/Ideas/Reviews | 20 | 24th September 2009, 10:29 AM |
| LM3914 Battery Monitor problem.. | cheewooi | Electronic Projects Design/Ideas/Reviews | 1 | 20th May 2005, 07:44 PM |
| measuring 12V or 24V fan RPM using pic16f84 | GraveYard_Killer | Microcontrollers | 6 | 29th August 2004, 09:55 PM |
| 24v battery monitor | cool-agent | Electronic Projects Design/Ideas/Reviews | 2 | 3rd July 2004, 01:02 PM |
