If what you have 'right now' is working what do you want to change?
I need a two speed (both high and low speed adjustable through trim pot) oscillator. to drive stepper motor pulses. right now I am using a 555 ic the low speed I have a pot where one resistor is and a relay to bring the other resistor from 1k resistor to 0 k for high speed. my motor is running anywhere from 30rpm to 300 rpm its a standard i think 1.8 degree step so 200x whatever rpm x60 for pps.
so running at 30-100rpm for low speed then around 100-350rpm for high speed
adjustable low and high, and switchable between high and low.
My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
Alec's First Law:-
Every problem has a solution (given the right information and resources).
well....... not sure if there is a simpler way to do it? is there an IC that allows isolated resistor to be used in a circuit? I used a trim pot in series/reed relay. I looked at other forums, and someone wanted to use a series of resistors to do something similar but didn't see a solid answer. I tried a 4066 relay Ic but that did not work. I guess I was thinking about getting away from the reed relay. I know I could have just used a plc, but am not familiar wth the programming, and wanted to keep it simple. also I may want to eliminate the pots, and use an up/down button for speed control.
right now (RA) is a fixed 1k resistor and (RB) is a 1k trim pot to control speed. then added a dip relay to make 0 ohm connection between pins 6-7 (RB) which increases pulse speed as noted in osc. I think pin 7 is supposed to be the center on the trim pot then 6&8 on other sides ? I do not have it wired that way,, I have 2 seperate resistors. and was planning on using 1k trim pots on (RA) and (RB) currently using option (2) for (RB). when 0 ohms across pins 6-7 makes the high speed. It works but seems that there is a better way to do it? (the (RB) value may not be a 1k I am not home, but I think it is a 1k?
There are lots of ways to do this, but starting with what you have, you could replace the relay with one section of a 74HC4066, and control it with a 5 volt signal. 5V turns it on, 0V (ground) turns it off. Remember to connect pin 14 to +5V and pin 7 to ground. If you don't need the other switches in the package, put all of them in parallel, and drive all the control inputs with the same signal.
If this were my circuit, I would scale the pots up to 10k or 100k, and the 10uF cap on pin 6 down accordingly (1uF or 0.1uF). This is because you need a resistor in series with RA to protect pin 7 from a short to +5V when the pot is cranked to zero ohms. You could add 100 ohms, but that means pin 7 has to sink 50mA, which is kinda high, IMHO.
I did try to use a 4066, but could not get it to work for some reason??will a resistor feed through a 4066 as resistance? Thats why I used a relay, to isolate completely?
I can definately change the value of (RA) and (RB) and the caps for the correct balance/protection....the pulse signal is unbalanced anyways. so all that aside . is there a better way to acomplish an dual speed setup. I can get by with 1st slow speed (able to adjust speed on fly) and high speed fixed but adustable for setup/one time
The 4066 will work if you connect it correctly. The switch is isolated from the control. 74HC4066 has much lower on resistance than CD4066.
I'm assuming you want the low speed and high speed controls to be noninteractive. You need to tell us what the actual pulse frequency needs to be for , say, 300RPM.
hertz=1pps / 60,000 pps, is that 60khz? so I have used a mc104066, and think the 74hc4066 has similar values, the question remains..................
does the resistance carry through???? , you recommended changing the values of the resistors, is that because of the limits of the circuit? a mechanical relay has no resistance at all. is there a circuit that will induce a specific resistance into a circuit? , and is there a better way of a 2-speed controler? as far as interactve? not realy. same circuit, different speed low(adjustable)/switched high.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Variable frequency,high voltage and high current square pulse generator | soumyakant_prusty | Electronic Projects Design/Ideas/Reviews | 10 | 23rd April 2012, 03:22 PM |
| (BUCK BOOST)variable duty cycle pulse generator ....help!!! | pisaac001 | Electronic Projects Design/Ideas/Reviews | 4 | 2nd December 2010, 11:56 AM |
| (BUCK BOOST)variable duty cycle pulse generator ....help!!! | pisaac001 | Circuit Simulation & PCB Design | 0 | 1st December 2010, 07:25 PM |
| 5V Pulse Generator | Brocktune | General Electronics Chat | 3 | 4th November 2003, 08:11 PM |
| Variable speed DC 24V motor | raudet | Electronic Projects Design/Ideas/Reviews | 2 | 2nd July 2003, 05:50 PM |
