Normally a toggle switch is on-off-on. You need a 2P3T or 2 toggle switches. E
I am incorporating two 12 v LED light strings into a mirror frame for my bathroom powered by a DC transformer. One string points up, and one down. I purchased a mini toggle on-on-on switch for it that I would be able to turn the down lights on, or the up lights on, or both. As I started to wire it up, I realized that I would backfeed from my middle circuit making the switch useless as both strings would be on all the time. How do I prevent the backfeed on these two light strings, with a Diode? I found this on-line: 1N5818, 1A, 30V Schottky Diodes, would this work, and how should it be wired in? Thanks for your help.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| LED light resistance | Scratch | Electronic Projects Design/Ideas/Reviews | 10 | 22nd March 2012, 04:31 PM |
| Programable LED Light bar | donh69 | Electronic Projects Design/Ideas/Reviews | 4 | 22nd July 2004, 03:32 AM |
| Req for help with variable-power date-adjusted LED light | aprebyl | Electronic Projects Design/Ideas/Reviews | 2 | 8th April 2004, 09:32 PM |
| how to connect a LED light to a switch? | electronicswannabe | Electronic Projects Design/Ideas/Reviews | 19 | 20th July 2003, 09:52 AM |
| 30 led light from chip output ?? | shohag49 | General Electronics Chat | 1 | 18th April 2003, 11:01 AM |
