Normally On Blinking Light Bulb From 555 Timer Circuit
  1. #1
    Circuit Dude Circuit Dude is offline
    Hi all,
    I’m designing a circuit that will use a 555 timer to blink a light bulb. However, the bulb needs to be normally on and will blink only after the timer starts oscillating. The light bulb load will be 12VDC at ~5A.
    Attached is a schematic of a circuit that I built using a N-channel enhancement mode MOSFET. The design works great with an LED. However, once I replace the LED with an incandescent light, the bulb stays dark. Does anybody have suggested changes to this circuit that will make a bulb like an automotive taillight blink?
    Thanks for your help!
  2. #2
    colin55 colin55 is offline
    Where did you put the globe?
    0
  3. Thread Starter #3
    Where the LED is shown.
    0
  4. #4
    It must go in place of the resistor.
    0
  5. Thread Starter #5
    Thanks for the suggestion. The globe now blinks, but it is normally off. I need it to be normally on.
    0
  6. #6
    Try the first circuit. Obviously use the correct value components.
    0
  7. Thread Starter #7
    Will do...does the globe stay, as you previously suggested, on the drain side of the MOSFET?
    0
  8. #8
    The globe stays the same
    0
Strobe Light Triggered With A 555 Timer Circuit (Relay perhaps??) capasistor Electronic Projects Design/Ideas/Reviews 1 5th April 2011, 07:49 AM
Need help on how to program blinking light bulb in PLC black_wing_diaz Electronic Projects Design/Ideas/Reviews 11 4th October 2010, 12:27 PM
I/O pin to sense/control light bulb from PIC drkidd22 Electronic Projects Design/Ideas/Reviews 4 9th June 2010, 07:39 PM
Traffic light system using 555 timer jemilsan Electronic Projects Design/Ideas/Reviews 16 22nd February 2009, 04:05 AM
how to get a continuses singnal/pulse from 555 timer Gabrielle Electronic Projects Design/Ideas/Reviews 1 14th August 2003, 04:23 PM
Page Time: 0.08916 seconds      Memory: 7,507 KB      Queries: 17      Templates: 0
