Originally Posted by
throbscottle
You could implement a "soft start" circuit where the current is drawn through a resistor for the first second, or few milliseconds, whatever, then the resistor is shorted out for normal operation. It's easy to do using a relay, though a low Rds(on) mosfet would do the same job - I'm not too familiar with mosfets though.
Ok here's a diagram (based on your first one) to illustrate what I meant in the first place, with the soft start added in. The over-current protection will only limit the output to the 317's lowest voltage which is about 1.2volts? but that should be adequate for most things most of the time - any more severe conditions and the 317's own protection will cut in anyway. I'll leave it to you to calculate R91 and R92.
If you had 2 sets of contacts on the relay, the other set could ensure the output from the circuit is connected only when the surge current is finished. I'm thinking you could possibly build this into your over-current protection too - but you would need a latch/reset mechanism so it starts getting complicated again.
