variable DC power source 0-600V @ 1A max, analog or digital controlled
  1. #1
    mencinni mencinni is offline
    Hello all !
    i need to build a power-source, from 0V to 600V DC, 1A.
    i'm in canada, so i have access to 110V AC, or anything from a DC transformer
    last time i built a powersource, it was with a VARIAC (0-150V output, 20A), then a transformer (110V to 500V), then through a diode bridge. The output was variable, was more or less DC, and was doing OK. Problem was the weight, about 22lbs, and its supposed to be a portable device.
    I saw something similar, that was using 12v dc and could produce 0-500V DC. It was digitaly controlled, anybody knows how to achieve that ?
    any links or plans would be really appreciated
    Mencinni
  2. #2
    Sceadwian Sceadwian is offline
    1amp at 600V is 600watts.. that's neither a safe voltage nor a safe current at that voltage to work with if you don't know what you're doing. You could do the same thing with the Variac with a 6-1 step up transformer before the variac, but that's not going to do any favors to your dislike of weight. I'd say a commercial unit but something that can do what you want it likely to be pretty expensive!
    0
  3. Thread Starter #3
    woah thanks for the fast reply
    in fact, i know what i do, my company has been using such power-supplies for more then 10 years ! without accidents ! or very small accidents (we drive that current in the ground, and i felt some bit of voltage a few times, nothing harmfull)
    i'd just love to get a lighter version of the device, and if possible cheap. Something around 500$ of mats would be suitable for me.
    but thanks !
    Mencinni
    0
  4. #4
    You should be able to get close to a fully functional commercial unit for 500$ I would recommend searching more on the Internet in general.
    0
  5. #5
    bountyhunter bountyhunter is offline
    When I was at Power Ten, we made 19" rack mount power supplies that were about 1kW in various output voltage configuration. Believe me when I tell you: go to ebay and buy one. You will never build one in any reasonable time frame. As said above, it's also quite dangerous.....
    XTR 600-1.4
    http://www.sorensen.com/products/XTR...ifications.htm
    http://sairushelectronics.tradeindia...-Supplies.html
    https://www.valuetronics.com/detail/...m#.T3VN_vnGrQI
    http://www.ntecusa.com/product/dsp_u...?modelID=22309
    http://www.testequity.com/products/2155/
    0
  6. Thread Starter #6
    <edit>woah thanks for all the links
    at first i thought it was spam in your signature, very interesting !! </edit>
    i found something that would look like what i want :
    http://www.us.tdk-lambda.com/hp/prod.../genesys1u.htm
    if you scroll down the table: its 680W, 0-600V DC, 0-1.3A.
    Problem is that is not made to be used outside, it can rain, it can be very hot... and its costs about 2200$US
    Judging by the size of the box, it doesn't look filled with 6kg transformers... must be electronicaly amplified...
    i'm looking over voltage doubler or tripler... maybe it can be something that helps, even if that means finding huge capacitors...
    any ideas are still appreciated, even "its too hard to make"
    i've done 3 years in electronic college, i have the basics (even if i'm a little rusty now)
    Carl
    0
Variable DC Power Supply Night Thrasher Electronic Projects Design/Ideas/Reviews 8 10th January 2006, 12:11 PM
power source isolator needed? jrz126 Electronic Projects Design/Ideas/Reviews 2 20th October 2004, 08:26 PM
simple 6volt power source throttle63 Electronic Projects Design/Ideas/Reviews 1 3rd August 2004, 07:21 PM
AC Power source Sarac Electronic Projects Design/Ideas/Reviews 12 18th July 2003, 05:26 PM
12v mobile small power source lazynok Electronic Projects Design/Ideas/Reviews 1 9th June 2003, 08:05 PM
Page Time: 0.05125 seconds      Memory: 7,398 KB      Queries: 16      Templates: 0
