LED fade in/fade out
« First 123456 Last »
  1. #21
    ljcox ljcox is offline
    Quote Originally Posted by alec_t View Post
    @colin55
    The circuit in post #15 will need adapting to get a 30 sec fade period. It currently gives a 3-4 sec period.
    Re Ohm's law, take a look at the stated voltage at point X in the schematic and work things from there.
    Thanks alec_t, that seems to be the point he is missing.
    0
    Len
  2. Thread Starter #22
    1-3-2-4 1-3-2-4 is offline
    What is replacement for the IRFH5306 that's not surface mount?
    0
  3. #23
    alec_t alec_t is offline
    Google for n-channel mosfets.
    I'm not recommending any particular manufacturer, but here's a page selected at random
    http://www.vishay.com/mosfets/n-channel/to-220-package/
    Just pick one with Vds at least 30V and Rdson less than ~ 0.05.
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  4. Thread Starter #24
    http://www.vishay.com/mosfets/n-chan...o-252-package/
    If i searched right I don't think digikey has any with this rating Mouser has it but digikey arrives a little faster and with the recent storm that hit TX might slow it down some.
    0
  5. #25
    Mosaic Mosaic is offline
    If i were to try this I'd use an LM317 or 338 with a voltage divider and an RC component on the reference leg of the regulator. So basically you'd get a slow ramp up and down on the voltage which will translate into brightening and dimming of the LEDs via a dropping resistor. No other IC's or transistor drives needed. You will need a DC supply of about 1.5V over the target max voltage though.
    I've used a PWM technique into an RC filter on such a regulator b4 to create control of a linear voltage for batt. charging.
    0
  6. Thread Starter #26
    That would mean I would need to change my power supply however.
    one question can I do without the mosfet?
    0
  7. Thread Starter #27
    I feel stupid for asking this but C2 is that 0.1uF?
    0
  8. #28
    audioguru audioguru is offline
    Quote Originally Posted by 1-3-2-4 View Post
    Which schematic?
    100nF is 0.1uF. A "Western" 0.1uF film capacitor is marked "100n". An Asian 0.1uF film capacitor is marked "104".
    0
  9. Thread Starter #29
    Quote Originally Posted by audioguru View Post
    Which schematic?
    post #11
    0
  10. Thread Starter #30
    going to use the IRF510 for the mosfet but I was going over the design and with those bjt's it would lower the gate voltage on the mosfet too much so I was going to omit them in the circuit.
    0
Fade-in, fade-out LED circuit - for car interior lighting. Midnightcarving Electronic Projects Design/Ideas/Reviews 13 8th November 2010, 11:07 AM
Need multi-LED fade circuit diagam 100fold Electronic Projects Design/Ideas/Reviews 3 30th August 2006, 06:19 PM
Led Fade in/out walnut Electronic Projects Design/Ideas/Reviews 1 14th October 2004, 11:46 AM
PWM - LED fade out!! Beth Microcontrollers 5 22nd February 2004, 07:45 PM
simple LED fade on / off mofotron Electronic Projects Design/Ideas/Reviews 8 6th May 2003, 02:22 AM
Page Time: 0.10195 seconds      Memory: 7,706 KB      Queries: 16      Templates: 0
