Why do you want to obfuscate the problem and not use a laser with a line generator that's visible to the human eye?
Hi.
I'm chasing a --CIRCUIT-- design to make a laser level receiver please.
It'll be about a foot high, with maybe 40 vertical LEDs. I'd like ONE of those LEDs to light up when the photo-diode(?) beside it detects the laser beam, thus showing me where on the detector the laser is striking. The laser level rotates at about 500rpm, I assume the detector circuit will have to detect this faint laser pulsing differentiating it form ambient light readings? I'm not too bright, but keen for some help please?
The receiver will be in bright daylight, and will need to be seen from some distance, hence the interest in LED illumination.
I have appreciated numerous ideas offered, but unfortunately nothing has been a better solution for my application than singular led illumination, in a vertical column, about 250-300mm tall. From previous enquiries, It would also seem a successful circuit might relate to the cyclic pulse of the laser beam striking the detector cells, identifying it from the incoming bright ambient light.
This is not a new idea. These rotating lasers already have receviers/detectors that accurately read the beam from 100m or more away, with an accuracy of 5mm or less.
The problem is, the hand helds have a small detection height (2 inches or so) and usually offer a readout of high, on grade, or low. I wish to make a big one, that can been seen from a distance, that shows exactly where the beam is striking it, so I can see exactly how far off grade I am, from a distance, outside, in daylight.
Thanks.
Last edited by Duggie; 11th February 2012 at 02:02 AM. Reason: Better Clarification
The receiver will be in locations not close to a human eye. The LED illumination will be easier to notice clearly and quickly from distances, in daylight. The project is for earthworks. So your unable to assist with a circuit then I assume please?
You might want to look at the number of posts and rating the gent has before casting aspersions of valid contribution...
Back to task: at distance a simple linear repeater may suffer similar accuracy problems. May I suggest a simple encoding (74148s) then a display (7447s) of the number.
A uC would allow a deluxe answer: a 2.5 digit display of +/- 20, based on the 40 sensor array. Otherwise, the above would suffice...but either way you'll probably want to change 40 to either 32 or 64 <<<)))
P.S. In reading again, your issue will not be display for view. It'll be the scanner reception: I'd have the receivers look for a specific pulse rate as modulation. Trick will be rotational speed vs distance & maximum modulation rate. You may want to drastically reduce rotation speed for distance/accuracy.
P.P.S. there are Really reflective materials (3M highway grade stuff) that'll do Amazing things with an appropriate power beam.
Last edited by OlPhart; 11th February 2012 at 01:57 AM. Reason: Oh and another thing...
Sorry OlPhart. With 13000 posts, I (incorrectly) assumed Sceadwian would have noticed the -CIRCUIT- emphasis I tried to convey. (Evidentally not well..) I specifically included the word 'please' to try to minimuse incorrect perception of any ill-will. I note that did not work.. A display of the number? I'm not all that electrically knowedgable, do you mean like a 7 segment led number display please? If so, that unfortunately defeats the intent of this project sorry.(Can elaborate if needed.) If not, could I please have some more explanation and a circuit diagram please? Thanks OlPhart.
PS: Thanks again OlPhart. Added note to my 1st post, and I would not think the frequency of the beam striking the receiver would have anything to do with its distance from the source?.
Ok, I'm smooth... I thought a number to read would be easier to interpret than a point on a scale at a distance. The bit about rotation vs distance and any kind of pulse frequency for recognition is based on simple geometry about how long a signal is over any given point at the given distance.
I'll 2nd the use of a higher power laser (careful there) and ultra-reflective strips. It's almost always easier/cheaper to centralize the power than distribute the sensor/receivers.
Another consideration: At a receiver/repeater, what kind of LED at what 1/2 beam angle and power consumption were you expecting to see at what distance?
In further review, (I)we need to see the map of optical power vs distances involved to better detail the problem. Angles, beam widths, and power are not trivial outdoors especially at distance (>100'). It's the main reason LED flashlights are no threat to deer shining...... (teehee) <<<)))
Last edited by OlPhart; 11th February 2012 at 02:47 AM. Reason: optical power vs distance
From my experience, analogue displays are subliminally easier to quickly mentally register than digital readout. Hence my desire for one of 30 LEDS to illuminate than to read a led numeric display. The present detectors produce an accuracy of abt 3mm over 300', so there's a chance the beam stays tight / narrow over that distance. No, it is not definite, the existing circuitry might detect on 3 cells, then average out to the middle one.. I already have the laser. Just wish to make a bigger receiver. Not sure where a repeater comes into it. The trouble I seem to be having is not many in the electronics forums understand what a rotary laser level is. Laser beam shines vertical out of level, rotating mirror above it spins the beam horizontally 360 degrees, abt 400-500 rpm. That produces a virtual level plane, NOT changing height. Somewhere off in the field you raise and lower a detector, when it says on grade, you measure down from there to ground to compare your ground height reading to that of the virtual level plane. I was assuming if laser was spinning at 500rpm, detector would be detecting a pulse hitting it at 500 times / sec 3' away from level, and 500 times / sec 300' away from level. The Leds can be shadowed into recesses to make them a little more noticeable in the daylight, I'd like to see them lit up from maybe 100'. In my experience, if my kids shine their led torch at me 300' away in the day outside, I can see when it is on, or off. No, it won't help me read a newspaper in the dark at that distance, but I'll see its on looking at it.. If I can invest the time, I should make a drawing to better explain.
As the receiver has to detect tiny light pulses, you'd want to use a photodiode rather than phototransistor due to the response speed advantage. You'll also likely want to use a high-pass filter to remove the effect of ambient light (that's what C1 does in the attached circuit; I1 is the photodiode).
Have a look at the attached circuit and simulation for a circuit designed to receive laser pulses; the output is also a pulse, so you'll probably want to extend it before driving your indicator leds. R1 sets the sensitivity and working range. the pulse width in the simulation is for ~100' (very roughly) based on 100' * 500RPM --> 1700m/s & with a dot of 4mm, that's a pulse width of 2.3us.
If there's too many parts in that circuit (as you'll have to duplicate it for each LED), you may wish to look into using CMOS inverter gates as amps, which may give a usable result.
https://sites.google.com/site/pk2devicefileeditor/
I'm not clever enough to know if that circuit will work, but it seems to be the best response to my enquiry to date BY FAR.
Extremely appreciated! I'd love to get that out pulse to trigger an led illumination for about 2 seconds please?.
If I can get the just mentioned led action, I could make one of these, turn it on, and 'swipe' it past my spinning laser and see if it works.
I have circuit wizard to emmulate it, but I don't know how I'd simulate the laser pulses into the photodiode..
Again, I'd like to offer my sincere appreciation for your circuit, its what I've been hoping for for a long time.
What about a picaxe chip & program to handle part of this / multiple photodiodes?
It works - real world - with a 10us laser pulse; I have tried it. The variables include the illumination brightness, and turn-on slope (due to the speed of the photodiode and of the rotating beam).
You can just poke a 555 timer after it for now for your bench test. Circuit attached (there are other ways of course)
You will still need the amplifier to be implemented for each photodiode; the extending of the pulses and controlling of the LEDs may be done by a microcontroller (possibly picaxe but I don't know).
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| RF Power Level Detector? | mindctrl | Electronic Projects Design/Ideas/Reviews | 9 | 20th October 2006, 09:12 PM |
| Liquid Level detector and indicator | Langat | Electronic Projects Design/Ideas/Reviews | 4 | 27th September 2006, 02:13 PM |
| fuel level detector | aibelectronics | Electronic Projects Design/Ideas/Reviews | 1 | 12th December 2005, 01:39 PM |
| HELP ME BUILD A GPS receiver PLEASE! | z24 | Electronic Projects Design/Ideas/Reviews | 6 | 10th September 2004, 08:46 PM |
| LM1830 fluid level detector equivalent | udi_hakim | Datasheets, Manuals or Parts | 2 | 25th January 2004, 08:22 PM |
