Need help to design a circuit for a auto door opener for chicken coop
12 Last »
  1. #1
    DOM01974 DOM01974 is offline
    Im making a auto door opener for my chicken coop, It must run from low power so 4 AA batterys would be good i need a timer so it can power a motor at 8am everyday to open the door and a push button to revert the power so the door closes, the motor would have a spool on it to wind the door up and down using string. the door weighs around 2-3 kilos (maybe less) any help for a circuit design, i could go buy one but thay are alot of money for somthink that could cost alot less to make.
    also it going to sit inside a waterproof box.
    any help would be welcome
  2. #2
    Sceadwian Sceadwian is offline
    Can you post a link to a unit you've found that you think is too pricey?
    0
    could mum, but I be a cat and no cat anywhere ever gave anyone a
    straight answer, har har."
  3. #3
    found one on ebay VSB opener
    0
  4. #4
    Boncuk Boncuk is offline
    Hi DOM01974,
    I guess what you have found is just the "black box" for the coop. It doesn't seem to contain any mechanics.
    Here is a simple mechanical solution.
    Use single steel rods (bike spokes will do it perfectly). Bend them circular and attach them to the horizontal steel bar using spacers of copper pipe.
    Each rod should move independently making passage for the chicken easy.
    Depending on the desired function you might lock the chicken in, out or both using locking bars at the bottom of the device. They might be driven by solenoids.
    You might think about purchasing a programmable timer switch offering two channels for on and off independently. They are available at electric suppliers.
    Boncuk
    0
    I spread chaos where ever I am. Too bad I can't be everywhere.
  5. #5
    thanks boncuk but dont think that realy helps as im looking for a timer and some sort of pully system unless iv missed somthink on your post ill build what u have shown and get back to you i realy dont want to get up early in the morning so a auto opener to pull the door of the coop upwards at 8am to let the hens out, as u can see in these photos the motor pulls the string to allow the door to go up or down
    0
  6. #6
    also heres a vid of this unit in operation
    0
  7. #7
    alec_t alec_t is offline
    Someone else here was doing much the same. Look at
    little help needed?
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  8. #8
    great stuff alec_t thats the sort of thing im after thanks a bunch
    0
  9. #9
    Jugurtha Jugurtha is offline
    http://www.youtube.com/watch?v=qUKIlZIZDqc
    I like this one too .. It has a little neat system that makes it impossible for the door to be opened by the outside (animals that eat hens can't open it)..
    0
    ~Jugurtha Hadjar,
  10. #10
    I don't see any advantage of a sliding gate, but risks for the survival of chicken.
    Assuming the gate has already been closed with one chicken getting home late it will have to stay outside and might fall victim to a fox or a marten.
    Chicken don't return home after dark if there is sufficient artificial light (street lights, etc.) making them "think" it's still day.
    (That's the reason why chicken are being raised in a lighted environment 24 hours per day, making them eat all day and night long to grow faster for meat production and profit.)
    Just give it a thought.
    Boncuk
    0
12 Last »
need help with touch switch circuit for 3.6v moinmoin Electronic Projects Design/Ideas/Reviews 4 10th May 2008, 01:41 PM
Need Help To Design A Circuit Dagwood Electronic Projects Design/Ideas/Reviews 7 29th May 2007, 11:51 AM
Need help ro design a "heart rate monitor" circuit elrikdo Electronic Projects Design/Ideas/Reviews 1 18th May 2004, 08:21 PM
Need help ro design a "heart rate monitor" circuit elrikdo Electronic Projects Design/Ideas/Reviews 0 18th May 2004, 07:20 PM
Need Help In finding a circuit for my Key Safe project Help! fig Electronic Projects Design/Ideas/Reviews 0 22nd October 2003, 03:50 PM
Page Time: 0.04477 seconds      Memory: 7,323 KB      Queries: 17      Templates: 0
