35amp test unit?
« First 12
  1. #11
    tcmtech tcmtech is offline
    If you need more wattage capacity just use nine 3 ohm resistors like what RR has linked too.
    As far as wire gage goes in typical test lead applications multi strand 10 ga would be more than sufficient for a 35 amp load.
    0
    "Only someone with something to hide has reason to fear open and honest communication."
    The scariest thing about where I work is that I am the good employee!
  2. #12
    Diver300 Diver300 is offline
    Quote Originally Posted by browningbuck View Post
    yeah that was what i was thinking about, but i guess that would be 8X 55w laps.... maybe its what i do? im waiting on tcmtech. i like his idea, just trying to figure out if its stable for testing say 100 batteries over a few hours?
    Headlight bulbs would stabilise the current better than resistors. With a resistor, the current will fall 10% if the voltage falls 10%. With bulbs, the current will fall less, maybe only 5%, if the voltage falls 10%.
    If you are testing 100 batteries in say 5 hours, that is 500 seconds of load in 18000 seconds, so the load is only being used 3% of the time. If you are using wirewound resistors like the ones suggested, you don't need a big heat sink at all. I suggest that you bolt the resistors to a flat bit of metal, as you will need somewhere to mount them anyhow. If you have enough space to bolt them down, that will almost certainly provide enough heat sinking for the amount that they are to be used.
    Wirewound resistors like that are rated at 5 times overload for 5 seconds, so using three 50 W resistor, totalling 150 W, at 350 W for 5 seconds is fine.
  3. #13
    Boncuk Boncuk is offline
    Hi Brian,
    you could use that circuit with some modifications.
    It was designed as a current dump for wind generators to act as a brake in stormy conditions.
    The circuit can dissipate a total of 660W for the required time you need for testing.
    Connect any required load to the output (preferrably resistive).
    The circuit will turn off the MosFets when battery voltage has dropped to a sufficient level.
    Omit R7 and C3 for instant action.
    Boncuk
    0
  4. #14
    4pyros 4pyros is offline
    well i am trying to build a 35Amp test unit. the idea is a 12V battery will be hooked up for max of 5 sec at a draw of 35A. this is a fairly large draw and i do not know what has a 420Watt device i can use? the power doesnt need to be used. it can be dissipated as heat, or light or... what ever. it is to test the internal connections of the battery to insure that all connections have been tested for QC reasons.
    any ideas would be greatly appreciated.
    Brian
    Can you use an off the shelf car battery tester? Thay have nice big resisters inside.
    0
  5. #15
    Reloadron Reloadron is offline
    Brian
    I guess what some of all this comes down to is if the OP wants to actually monitor battery current / voltage or just load the battery for about 5 seconds with about a 35 amp load. My take is the latter. No mention of monitoring or switching the load. So some big load out there and that is about it.
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  6. Thread Starter #16
    browningbuck browningbuck is offline
    Ron your correct, its a pass or fail, if the battery is capable at 35A then the battery passes. i will of course have a amp clamp on there to monitor rough Amp measurements. i like the water heater idea and i think diver300 touched on a GREAT point. however the stupid head lights seem the most cost efficient and stable and 10awg is design (which is capable of a 35amp design)
    0
  7. #17
    Thay have a inrush current till thay get warm.
    0
  8. #18
    While headlamps are a novel approach I would use resistors. As to things like inrush current with any incandescent lamp? I figure we are looking at literally milli-seconds in the big picture. Considering the time involved? Looking at 5 seconds using a clamp on to note the current this is not quite an exacting science, a rough pass or fail. The AWG 10 should be just fine.
    Ron
    0
« First 12
K190 temp sensor and control unit test/repair ghostman11 General Electronics Chat 0 14th January 2010, 01:32 PM
short circuiter unit electronicalman Electronic Projects Design/Ideas/Reviews 9 9th March 2003, 11:04 PM
ASCII Symbols Test kinjalgp General Electronics Chat 9 1st February 2003, 06:15 PM
review book/test sycon8 General Electronics Chat 1 12th December 2002, 03:06 PM
CEDETA targeted anesthesia unit. Magic Datasheets, Manuals or Parts 0 11th December 2002, 11:24 AM
Page Time: 0.10307 seconds      Memory: 7,656 KB      Queries: 17      Templates: 0
