When the crystal is made it is made based on some required capacitance values to be used with it. This means it is cut so that it resonates at the package stamped frequency WITH that capacitance included in the circuit. If the caps are not there, the crystal oscillates at a slightly different frequency. The caps also affect the temperature characteristic of the frequency and oscillator start up reliability. It may not matter that much though depending on your circuit and the required accuracy and temperature curve.
If you need a really really accurate and stable clock, you should look into some ready made oscillators that are made for more accurate applications. Stand alone crystals plus or minus caps do not make good real time clock oscillators for example for real time clocks that have to operate over a period of say 6 months or more.
So the question for you is what are you going to use this for. That makes a big difference in just how critical these cap values are and even if you should look for a different oscillator type altogether.
