Convert High Voltage AC Signal into Low Voltage DC Signal
12 Last »
  1. #1
    electrousa electrousa is offline
    I need to design a circuit which converts 220V AC signals into 3.3V DC signals.
    The 220V AC signals are part of elevator system which is used to detect every single elevator's status and report to a central control unit or something like that.
    The 3.3V DC signals are to an embedded micro controller which is on my board.
    What I need to do is to find a circuit which converts the 220V AC signals into 3.3V DC signals and finally can be interfaced to my micro controller.
    I have no knowledge on the elevator system so if anyone have advices on how to converts 220V AC signals specially in elevator system to 3.3V DC signals, that will be great appreciated.
    Any general knowledge on how to convert high voltage AC signals to low voltage DC signals are also great!
    Thanks in advance.
  2. #2
    ronv ronv is offline
    Maybe a little more info would help.
    Are you trying to detect the presents or absents of 220 volts by converting it to a 3.3 volt dc signal.
    Or are you building a power supply to convert 220 to 3.3 vdc.
    0
  3. #3
    crutschow crutschow is online now
    The easiest and safest way is to use a small transformer. 220V to 2.5V AC would be good but 6.3V AC outputs are likely more common. Just rectify the AC with a diode and capacitor filter, and then reduce that to 3.3V DC with a series resistor and a 3.3V zener diode to ground.
    0
    Zapper
    Curmudgeon Elektroniker
    --Inside every little problem is a big problem trying to get out.--
  4. #4
    Nigel Goodwin Nigel Goodwin is offline
    Super Moderator
    Quote Originally Posted by crutschow View Post
    Opto-isolators would be easier, safer, and a LOT cheaper
    0
  5. #5
    The reason I need to convert it to a 3.3 volt dc signal is trying to detect what information is carried through the 220 circuit inside the elevator system. I have no knowledge on elevator system...
    If somebody can describe something about the 220 volt ac interface(like how many wires and how it works etc.) for the elevator system that will be great!
    0
  6. #6
    alec_t alec_t is offline
    In that case how will you be able to interpret any information you detect? Why do you think there is information (as distinct from just power) in the 220VAC?
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  7. #7
    You are right from this point, It maybe just a 220V AC power. but the control unit need to judge the status of the elevator through this 200V AC ring.
    0
  8. #8
    Thanks for the information, I think it is a good idea to using opto-isolator convert the AC to DC easily.
    Any suggests on the part selection and circuit design will be greatly appreciate!
    0
  9. #9
    But we still don't know the nature of the signal you are trying to detect.
    0
    Zapper
  10. #10
    KeepItSimpleStupid KeepItSimpleStupid is offline
    Google "I/O modules".
    0
12 Last »
High Voltage Low Frequency AC Output from Solar Cells anoninmcd General Electronics Chat 2 3rd June 2010, 10:44 PM
Speed Control for Low & High Voltage DC Motors Freenerd General Electronics Chat 1 8th February 2009, 03:41 AM
Driving a low voltage motor with high voltage PWM paulr General Electronics Chat 6 6th January 2009, 02:33 PM
Low voltage vs high voltage programming bananasiong Microcontrollers 4 20th July 2007, 12:00 AM
AC motor wiring diagram for low/high voltage - how to wire?? bill123 General Electronics Chat 2 20th May 2004, 08:10 PM
Page Time: 0.04473 seconds      Memory: 7,307 KB      Queries: 16      Templates: 0
