Originally Posted by
Reloadron
With the existing circuit as drawn with the LEDs back to back so to speak the Vsat out of the comparator can never exceed the breakdown voltage of either LED, one of the two is always reversed biased so if the breakdown voltage of the LED is 5 Volts that is as good as it gets. The max current sink on a comparator like the LM393 is about 16 mA. Given a choice I would use the output of one comparator to drive a LED and the other to drive a transistor like a 2N2222 to drive the relay with a LED across it. This does away with the back to back LED configuration.
Ron
