Old 23rd April 2003, 04:51 PM   (permalink)
Default Solar Cell
I'm thinking of doing a project where by there will be a solar cell panel which will able to produce 18V(DC) and this output voltage is then converted become 240V(AC) 50Hz. Is there any way to do this? Please.... thanks! If possible, can you please give me the schematic diagram and part list as well? Thanks!
yewnen is offline
Old 23rd April 2003, 05:17 PM   (permalink)
Do an advanced search on google - for inverter - and you will find lots of circuits. Just adapt one to suit your needs.
As you are trading current for voltage you might find that you only have mA to play with at 240V.
Pilot is offline
Old 24th April 2003, 03:39 AM   (permalink)
is the inverter able to produce a 240V ac (13A) from a 18V solar cell panel? Any recommendation on what solar cell should I use? thanks!
I really need advice on solar cell. How big of the solar panel should I use to produce 18V of voltage? I'm a newbie here. Thanks for helping me...
yewnen is offline
Old 24th April 2003, 06:22 AM   (permalink)
240v at 13a? just rough guessing - about 2000 square feet of panel. :shock:
Mosfet is offline
Old 24th April 2003, 08:43 AM   (permalink)
Hate to think of the line losses connecting all those panels together.
I could cover my roof in panels & get just enough juice to power the pond pumps.
All i\'s dotted & all t\'s crossed.
Pilot is offline
Old 24th April 2003, 02:52 PM   (permalink)
I mean how what type of solar cell should I use to produce 18V DC output? any recommended inverter circuitry? thanks!
yewnen is offline
Old 24th April 2003, 04:40 PM   (permalink)
If the object is to end up with 240 volts, why are you stuck on 18 volts coming from the solar panel? Recommend you start your project with the inverter. You have already said that you want 240 vac @ 13 A output - right? Assuming you are sure about that, then look for an inverter that can produce that output. The input requirement of the inverter will dictate your solar panel parts, circuitry, and size.
I know this seams backwards from your original approach but I think it will do two things. (1) it will give you a definate plan that WILL work and (2) it will give you an appreciation of just how many solar cells are needed to get that 13 A you wanted.
Have fun....
Gene is offline
Old 24th April 2003, 04:44 PM   (permalink)
A four-inch silicon cell can produce about one watt of DC electricity.
Any size silicon cell produces approximately one half volt.
The above work in a perfect world, plan accordingly.
If you can get 10 amps of power at any voltage my hat is off to you sir.
Mosfet is offline
Old 25th April 2003, 12:21 AM   (permalink)
Most solar installations don't run the entire load off the cells, anyway. There is a battery bank, which supplies power to the inverter, and the cells are used to charge the battery, when the load is switched off.
The batteries can supply much higher current than the cells can... :P
Phasor is offline
Old 25th April 2003, 12:50 AM   (permalink)
So, I piece of solar cell with any size is able to produce 1.5V. In order to produce 18V, there will be 12 solar cells needed right?
Where can I get all the solar cells? which one is better or cheaper? I have found the circuitry of an DC to AC inverter, and I'm doing some studies in this.
Using a rechargable batteries will produce higher current? it's that true?
Please guide me, I'm still abit lost. Thanks!
yewnen is offline
Old 25th April 2003, 04:11 AM   (permalink)
yewnen,
You're right, you are lost!
You are not considering electrical quantities such as current (therefore power), which are more important then voltage in your situation. There is no way that you can power a 240Vac 13A load with a few little solar cells, it is impossible. Let's do a rough estimate here.. You are asking for 3120W of raw power at your load. Your inverting process isn't perfect either, so you are looking at probably 4000W of solar power including resistive losses. For example.. I found a 120W panel that is 56" X 26" that costs 732$.. You need around 33 of them, which equates to nearly 25000$ of solar panels and 4000 square feet of panelling..
If your average current was half, then you need about half of the solar panels, but you need a battery backup that will hold the charge until it is ready to be used. I hope that you find another solution to your problem..
Steve
Scubasteve is offline
Old 25th April 2003, 05:13 AM   (permalink)
1/2 volt per cell
0.5 volt per cell
one half volt per cell
18 volts = 36 cells
[better to get 40]
Mosfet is offline
Old 25th April 2003, 05:43 AM   (permalink)
Originally Posted by Mosfet
1/2 volt per cell
0.5 volt per cell
18 volts = 36 cells
[better to get 40]
Did you really need to show two other ways of saying 0.5V/cell? Let's not patronize this person asking for help, let's guide and show him the reality of the situation.
Steve
Old 25th April 2003, 11:13 AM   (permalink)
That's a good approach. Consider
1. 40 cells = 18 volts - producing almost no current.
2. Add another 40 cells in parallel and you get 18 volts with a little more current.
3. Add another 40 cells in parallel and you still have 18 volts but you can now measure the current with a very sensitive mA meter.
4. Add another 40 cells . . .
on and on and on....
Gene is offline
Old 25th April 2003, 12:27 PM   (permalink)
Steve
My apologies to all, my thoughts are on providing concise information, not patronizing.
My flippancy, when it occurs is far more obvious. Have you heard of transference sir?
http://www.rider.edu/~suler/psycyber/transference.html
Mosfet is offline
