Hi Magno,
I am sorry for mis-spelling your name before, I have corrected it. I would rather not connect the top of the LM3914's divider to the 555's pin 5 because it would change the 555's timing period. Besides, Max has only 6 LEDs so the top of the LM3914's divider will have to be at a much higher voltage anyway. Actually, since the top of the LM3914's divider will have to be above the supply rail, it is probably best to reduce the voltage at the divider's low end, and just use the last 6 outputs of the LM3914. |
Hi Max,
This project is becoming a can of worms. The 2.2K resistor that you put across the cap steals current from the current source so the cap will no longer charge linearly, and may not even charge high enough to allow the 555 to work. You mentioned a relay. I didn't know bikes use an expensive and failure-prone relay flasher when an inexpensive, simple electronic circuit can flash reliably. In a car, its clicking reminds you to turn it off, but on a motorcycle can you hear it? Why use this complicated 555 circuit when the flasher can do it very well? The flasher can apply power to the current source transistor which linearly charges the cap. The LM3914 is also powered and indicates the rising cap voltage on the LEDs. When the flasher clicks off, the LEDs also turn off and a P-channel junction FET quickly discharges the cap. When the flasher applies power, the FET is turned off. Really simple, do you like it? |
i don't hear no noise on the bike even if there was i wouldn't be able to hear it because exasht noise, wind and helmet. But it does Flash. so a light comes up when indicator is turned on. Relay is used for all 4 signals (left front, left back, right front, right back) When i hit the switch for right or left it just grounds the relay and it activates it. If i use the flasher to apply power to current source transistor, will have to mess with the flasher's wiring? or can i still use the wiring from the previous indicators? (pos / neg) sorry about dumb questions but i am still learning you guys are far more advance then me. do i need to find out what ype or flasher relay is it or anything? thanks i guess we will have to draw a new diagram for this method max |
Hi Max,
One thing about the flasher relay on cars: the flash rate becomes very fast when a light bulb is burnt out. So it might be fast on your bike when using low-current LEDs instead of a high-current light bulb. If you use the LM3914 in its Bar mode, the rate might start fast then slow during each scan. For cars, a "heavy-duty electronic" flasher was available to drive additional lights on trailers, etc. Their rate doesn't change with load changes. Maybe they are still available and will fit your bike. If your bike had 12V light bulbs, this circuit (the current source transistor circuit, the LM3914 and the new FET control) connects to their wiring. If it had LEDs, you must connect before their current-limiting resistor. |
thanks Max |
(permalink) | ||
stock bulbs are 12volt and if one bulb breaks they all will flash faster. if you put led's in your footpegs they will flash faster if there is no relay inline. basicly if the stock configuration is altered, it will always not flash correctly unless the output of the bulbs stay exactly the same |
Maxer,
If I had a better idea of what you were trying to do I could have given more useful information. Various make bikes use different methods for flashing the signals. Usually the older bikes use a thermal relay like the antique cars. Current passing through heats a bi-metalic strip which opens the circuit, then cools off and closes again. Low wattage bulbs or one burned out will cause the other bulb to light but not flash (not enough current). That is why LED bulbs do not work in these bikes. Others, like my '97 Triumph use the ECU to flash the bulbs using a relay to carry the current. No change if a bulb burns out or replaced with LEDs. Older bikes use the opposite signal bulbs to provide the ground path for the dash indicator. Pre-80's British bikes are positive ground. Everything else, I believe, is negative. Another point, most high ouput LEDs have a low visibility angle, some as little as 20 degrees. Someone in the next lane might not see your signal if they are too close (disregarding the fact that will not see it anyway as they are too stupid). |
Mine uses a Relay but i don't know if its thermal or not. but i do know when one is not working or broken other one still flashes. what i am tring to do is have a sequnce LED flash rather then just on and off... here is what i want Oooooo OOoooo OOOooo OOOOoo OOOOOo OOOOOO then back to Oooooo and when mode pin is connected to Pin 4 V+ on LM3914 it should have a different sequence like this Oooooo oOoooo ooOooo oooOoo ooooOo oooooO and i will add a small switch on the project box i place the circuit in. and the box will be placed in my trunk i can change it periodicaly if i want to.. or have the switch in another place in the front but not sure yet. so i would have 1 circuit per side. Led's i will be using will have only 20 deg light angle, but the way the LEd's will be set up it should be okay because for front i will be using lower MCD's and higher disspation angles maybe like 30 - 40. Audioguru brough this to my attention earlier in another posting. i also have other lighting Mods that are going to be done but i after i figure this one out. i am looking at the schematic right now and it says "turn signal relay" and it has pos and neg terminals... neg is connected to the switches. switches activate the turn signals offcourse and also the flashing light on the speedometer display. and postive wire is used as ground.. again i am not sure because i get confused between "convention flow" and "electron flow" since they are opposite. so i try to imagine the way current would active flow rather then how its named, and i just started some basic electronic courses. here is my wiring schematic i circled where the flasher relay is. To make it easier i highlighted wires from RElay red is Negative and Blue is Postive also its a 98GSXR 750 its first Fuel injection model out with suzuki. as seen in the diagram eventually pos side of relay is connected to neg, and bike doesn't shortcuit so i am guessing its a thermal relay? i gotta learn more about these types of relays... crap i can;t post it because its about 582,347 bytes can i upload it any where and post the link here? |
Okay i came up with this....
2 transistors. the flasher wire is the current wire used for indicator because it has pulse threw the bike flasher. and 12V be applied from seprated wire only hot when ignition is on. (gonna do that with a simple automotive relay... connect a current wire that is hot when ignition comes on to the electromagnet and make the connection from battery post the the circut on the other side of magnet) So this is what you were talking about right i am not sure about those resistors. Also if everything looks good can you identify all the values of the resistors and the POT and what type of transistors to use, thanks Max |
Hi Max,
Sorry for the delay. I have finally finished your circuit and simplified it, I didn't like your changes. This one should work but may need the 470K resistor changed to match the speed of your flasher. |
Thanks for helping me out i really appreceiate this max |
Hi Max,
The LED current is regulated at about 20mA each, and is determined by R1. That reminds me, you can get rid of R2 and ground pin 8. You can use any kind of LEDs: red, blue, white , UV or even a mixture of colours. The scan rate is determined by the 470K resistor and is about 1/2 second. You can use a 1M linear pot in series with a 180K resistor instead of the 470K resistor if you want to adjust it from 380ms to 1.25 seconds. This circuit will make all the LEDs off during the other half of the flasher's time. |
we can use a diode that will discharge that cap though that 470/1 W resistor when flasher is off so what is the use of those transistors? will the capacitor charge in log or linearly? If in LOg i wont recognize the small delay right? thanks max |
