I'm picturing a string of 8 diodes with each switch position. There would be a switch position, a diode cathode, a diode anode, and FET gate all connected together at each but the first and last (they would be missing a diode cathode or anode connection). Here's my question, when selecting minimum current, the last voltage of the last FET gate will be 7 diode drops less than the first diode. When selecting maximum current the FET will see the most voltage, will the FET gate handle that or work under both extremes. I'll sketch something shortly.
P.S. I thought of a similiar design using relays but was fairly sure there wouldn't be enough voltage to trigger the last relay after 7 diode drops.
Yes, exactamente.
If the last few diode drops are a problem (don't think they will be, just set things so that the gate with the most diode drops still gets sufficient gate voltage), you could use Schottky diodes with smaller drops (or germanium: 7 x 0.3 = 2.1V).
You would want to use P-MOSFET or PNP bipolar transistors for you switches if you are driving a grounded load.
What is the supply voltage that these switches will be connected to?
Zapper
Curmudgeon Elektroniker
--Inside every little problem is a big problem trying to get out.--
I definately don't want to use PNP transistors. Why P MOSFET for grounded rather than N-MOSFETs?
I'm still a little confused.
If the input is a rotary switch like you have shown why not just switch in the resistor values like 100, 50, 33, 25 etc.
Because some of the values required aren't (readily) available such as 16.3 and 14.7 ohms.
People like Caddock make custom value low ohm resistors that can be very accurate:
http://www.electro-tech-online.com/c.../07/TypeMV.pdf
Seeing as they are low ohms, hand winding these wouldn't be too big of a task if the wire was small.
Or just use a handful of multiturn trimpots. Pots would allow you to dial out errors from switch contact resistance or leadwire resistance or jfet resistance which will be significant at low ohms and high precision.
How about 10 + 6.8 and 10 +4.3.
Zapper
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Does anyone have schematics of this: "FLASH-Lab 77" | mysemcon2000 | Microcontrollers | 1 | 29th December 2009, 11:50 PM |
| question about a "2 Channel RF Relay Control Board" | jax1492 | General Electronics Chat | 2 | 26th May 2005, 09:03 PM |
| Designing sound system need help | electrogeek | General Electronics Chat | 2 | 10th December 2002, 10:45 PM |
| needing help designing circuit..... | hinchman68 | Electronic Projects Design/Ideas/Reviews | 3 | 8th November 2002, 12:45 PM |
| advice needed on designing power supply | 440uf | Electronic Projects Design/Ideas/Reviews | 14 | 24th October 2002, 05:12 AM |
