Old 21st April 2003, 05:17 AM   (permalink)
Experienced Member
thebigbasicq is on a distinguished road
Default A few questions regarding capacitors and solar cells...
1. What does 100n mean with reference to a capacitor?
2. Will I get a readymade inductor if I specify it's value(say 100uH)
3. In the following figure 'Out' is showing only one terminal of the audio out. Where should I connect the other terminal of the headphones?
4. What does a 12x solar panel mean? Does it mean that it has 12 solar cells attached? or It must give an output of 12Volts?
Thanx
U.S.S.R.
thebigbasicq is offline   Reply With Quote
Old 21st April 2003, 08:09 AM   (permalink)
Experienced Member
Sebi is on a distinguished road
100n=100nF=0.1uF
Headphone other pin connect to positive supply, and must be a high impedance type (1...2kohm)
The coil can be handmade on small ferrite.
Sebi is offline   Reply With Quote
Old 21st April 2003, 10:42 AM   (permalink)
Experienced Member
Chippie is on a distinguished road
Default Re: A few questions regarding capacitors and solar cells...
Thanx
If its a preferred value, you can purchase a ready made inductor..
100microhenries is a preferred value, getting one shouldnt pose any problem......
Chippie is offline   Reply With Quote
Old 21st April 2003, 03:23 PM   (permalink)
Experienced Member
droid is on a distinguished road
are you sure? i always thought the other pin was connected to ground
droid is offline   Reply With Quote
Old 21st April 2003, 04:01 PM   (permalink)
Experienced Member
Yes, droid sure, because this is not a push-pull output.
Old 21st April 2003, 06:18 PM   (permalink)
Experienced Member
Default If i want to make an 100uH inductor, how do i go about it?
Which wire do i use? How many turns should i have? How do i know what i have made is an 100uH coil?
U.S.S.R.
Old 25th April 2003, 08:45 PM   (permalink)
Experienced Member
john1 is a jewel in the roughjohn1 is a jewel in the rough
Hi thebigbasicq,
Here is a capacitor equivalents calculator.
You can download it for free at Moyer Electronics.
http://www.moyerelectronics.com/index.html
I'm not impressed with it,
using 1.5 megabytes to move a decimal point
is not my idea of good programming.
I dont like the layout much either.
But there you go, it should do just what you want.
Regards, John
john1 is offline   Reply With Quote
Old 26th April 2003, 01:57 AM   (permalink)
Experienced Member
Phasor is on a distinguished road
Not sure... what is this in reference to?
This is a good inductor simulator, which will give you the diameter, number of turns etc, for an air-core coil.
http://www.oz.net/~coilgun/mark2/inductorsim.htm
Phasor is offline   Reply With Quote
Old 26th April 2003, 02:50 PM   (permalink)
Experienced Member
Default About the first quote, it is in relation to the Solar Ni-Cd
charger. My questions are:
1. Can I use a bead type 100uH inductor?
2. The circuit of the Solar Ni-Cd charger requires a 12x solar batteries. What does that mean?
I am attaching the circuit.
Thanx
U.S.S.R.
Experienced Member
Thanx
U.S.S.R.
Old 26th April 2003, 02:53 PM   (permalink)
Experienced Member
Default Oops I just posted twice(sorry!)[no text]
U.S.S.R.
