the ferrite beads are RFC1; 2; and 3
This looked like a nice transmitter to build when I came across it on the web. But only later did I see it uses a negative -3 V power supply, and a hard-to-get ferrite core coil.
All I want to know is how to create a +4 and a -3 v supply that I can use, and how could I substitute the ferrite beads with 6 holes.
It doesn't specify the voltage rail (there's only one!) on that circuit - those are just pin numbers, notice 1, 2, 5 and 6 are there as well.
Nigel goodwyn, are you saying that the bottom rail is in fact ground, and that "line" 4 goes to an unknown + voltage that is not given on the schematic?
If so, that solves the supply V problem.
The extremely old circuit is a Smartkit from Greece and is posted at Electronics-Lab 4 Watt FM Transmitter
Its single-polarity supply is 12V to 18V.
It is designed to use a very old "crystalic microphone" and needs a modification to use a modern electret mic.
It does not have pre-emphasis like all FM radio stations have so it will sound muffled without high audio frequencies on any FM radio.
would it work if I used the mic input to feed an audio signal into directly, or would I have to match the impedance to a crystallic mic. If so, HOW.
An audio signal has a much higher level than a mic signal so an attenuator is needed.
A 4W transmitter is illegal in most countries without having a licence to operate a radio station and that poor quality old circuit is not good enough to be a radio station anyway.
Thank you, the circuit is only as an intro into RF. And besides, I'd rather be a guy that prefers science to abiding the law.
I'll google a suitable attenuator. BTW you specifically have been helpfull at this site, since when have you been interested in this wonderfull world (hobby?) of electronics?
You must not break the law with a poor quality high power transmitter because it causes all kinds of interference to aircraft communications and guidance signals, FM radio, TV, police, ambulance and fire department radios.
Make a radio instead of a transmitter as an intro to RF.
I began playing with electronics about 55 years ago. I built an AM radio about 51 years ago. I built an FM tuner and amplifier about 49 years ago and I built an oscilloscope about 48 years ago. I built a low power FM transmitter about 47 years ago and built a much better one 6 years ago. My entire career was in electronics, mostly sound systems.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| I really need your help with this my fm transmitter circuit project !! | Mg Myo Ko | Electronic Projects Design/Ideas/Reviews | 3 | 19th August 2010, 05:28 PM |
| Bluetooth to FM Transmitter Project | MikalCarbine | Electronic Projects Design/Ideas/Reviews | 4 | 24th September 2009, 08:57 PM |
| Comm2 project... (transmitter help) | Kitrax | Electronic Projects Design/Ideas/Reviews | 1 | 6th April 2009, 04:55 PM |
| IR Transmitter / Receiver Project | Omar.M | Microcontrollers | 3 | 23rd May 2008, 08:11 AM |
| Transmitter/receiver radio project | TR | Electronic Projects Design/Ideas/Reviews | 1 | 7th May 2005, 07:31 AM |
