burglar alarm with IR sensor
pink_scarf
I need to construct a burglar alarm with an IR sensor and LDR for an electronics project.
I can make 2 separate circuits or combine them as one. However I need a circuit diagram to start building it.Please help me.
Hi, pink_scarf. Welcome to ETO! :)
I'm not sure quite what you mean--You want to use an IR sensor AND an LDR? Those are two different types of sensors. Perhaps you meant an IR sensor and an IR emitter? A bit of clarification could be helpful here ;)
Der Strom
nope..thats not what i meant..the ir led & ir reciever is a separate thing and the ldr is a separate thing..
i need a circuit which incoporates both IR and LDR.
If i dont get it i'll just use 2 separate circuits one with the LDR and one with the IR
Please let me know in case u come across a burglar alarm circuit which meets the specifications
Sorry thats still not very clear, I imagine the IR emitter and receiver would be a "beam break" type of alarm.
But what is the LDR for ?
hi Brevor,
I think what he is asking for is a combined detector that uses an IR detector and LDR detector, in series or parallel, which gives an output if either, or both of the detectors is/are obscured from the remote IR emitter.???
