Hi, this is supposed to be my final year group project. A solar toy car that can be controlled from a PC.
--About the project--- The solar panel can give around 8-10V output. Then the output goes through a boost converter to charge up the battery (planning to use a battery from the motor bike). The output from the battery will be used to power up the motor for the solar car. We intend to develop a program using Visual Basic as interface to control the car which communicates with the user using an RF link. The user should be able to control the movements of the car and the car should feedback the status of the car for monitoring. ----- The planning seems good but the problem is that it seems mighty hard to implement because it involves electronics, programming, communications and mechanical. We are still in the planning stage but having problems with the car controlling part using RF transmission due to lack of knowledge. Anyone have any experience on this kind of thing? welcome all the helpful advice that i can get. |
Have you evaluated the performance of your solar panels yet?, I suspect you are going to require pretty large ones!. |
You can get 433 mhz transmitter and receiver from Qkits (http://store.qkits.com/), the price is under $10 each. Small and efficient antenna is available from Mouser (www.mouser.com), part number 240-4311-121-20043.
Mouser also has RS232 modules.
see my website: www.geocities.com/russlk |
I like these guys myself: http://www.rentron.com/PicBasic/RemoteControl.htm They walk you through every step. :wink: Their prices aren't bad either.
Rain
When life gives you lemons... make a battery. |
You dont need the DC to DC Converter..
here's why.. the solar panel output is more like 12-15 V ( mine was 18V no load) and will adjust itself to the battery that you are charging.. what is the voltage of the battery in question 6V ? 12V? |
Even if the battery is 48 volts, you are better off to increase the solar collector voltage than use a DC to DC converter which will waste power.
Thanks for the advices.
The cheapest solar panel that we can find only provides around 8-10V. The battery would be around 12V. Therefore was planning to use a DC/DC converter to boost the voltage. Is there another workaround to this problem? Oh i am also very new to the remote control concept (that's why i am an electronics newbie How do i control the movement of the wheels? Where to turn etc... I heard that i should use a servo motor instead. Does it turn according to the servo motor or the servo motor turns to activate some circuitry that allows it to turn in a certain direction? Sigh... so much to read and learn. |
(permalink) | |||
$10.00 american and it came with a simple radio control to boot.!! |
Thanks again for all the helpful advice. |
What are the provided specifications for the panel?. As for the current required, it depends on a great many different things, and also what you require from the finished device. As it's going to contain a rechargeable battery you could let it charge all day, then have ten minutes running time - but if you require the panel to provide power for the unit continually, it will need to provide more than the complete power requirements of the unit. For a start I would do two things: 1) Find out how much power the panel can supply. 2) Measure how much power the rolling chassis is going to require, bearing in mind increased load will increase motor consumption drastically. Measure with different weights on the chassis, and climbing up slopes. The rechargeable battery will provide the extra power for high loads, but the solar panel needs to provide enough to drive the unit normally, and have enough over capacity to recharge the battery. This should give you some indication of how much power you may have left (if any) for the electronics involved!. For an educational project it gives lots of scope for interesting design possibilities, marks will probably be improved by including the design challanges you meet, and how you overcome them!. |
Newbie questions on RF.
1) How do i know how much frequency do i need for my design? Do i really need to go up to MHz if my transmission range is around 7-10m? 2) Will any antenna suffice for a 10m transmission? 3) Which do you think is better? AM or FM? thanks |
