Old 8th October 2004, 12:53 AM   (permalink)
Default Relay making a whining noise
i have a 250 ohm coil, .5 amp contact relay that im activating from a 555 timer in monostable mode. when not active, the realy made a high pitched whining noise, like a capacitor charging, only decreasing in pitch. after a while, the circuit stopped working. i tried replacing the timer. no luck.
thank you for any suggestions!
batman is offline
Old 8th October 2004, 04:40 AM   (permalink)
Do you Know if the Relay Contacts Are Chattering or is the Coil Humming?
John DeRosa (Hotwaterwizard)
hotwaterwizard@aol.com
hotwaterwizard is offline
Old 8th October 2004, 11:35 AM   (permalink)
i have no idea which it was
i would describe it as humming though
is there a way to tell?
batman is offline
Old 8th October 2004, 01:33 PM   (permalink)
The humming can be caused by a number of things.
1) Poor filtering on Power Supply.
2) Oscillation from Timer Circuit (also Called Ringing)
3) Poor Ground Connection
4) Negitive Pulse with a negitive Common lead on the Relay
5)Low Voltage from the output Pulse causing the Relay to Barely hold.
You may need to Run the relay with a Transistor to stop the Humming.
Check the voltage of the Timing Pulse.
