Waterfall printer or limited budget pick one.
hey guys,
i'm trying to do a waterfall printer as in the hyundai i45 commercial (i45 Commercial - Hyundai Motor Company Australia). Im not sure where and how to start. ive got a limited budget. Can anyone help me please ?
thanks
Tooooo cool. Do you want a big one like theirs or a little one?
The hardest part of that entire project will be the valves themselves, everything else is really not that complicated or expensive. I'm just guestimating but there's probably a good 500-600 electrically actuated water valves. If they're 5 dollars each... well you do the math. Find cheap valves and you might get the cost down to 1 or 2 thousand dollars for something of that scale. Go for smaller valves or make them yourself and skies the limit, depends on how good a fabricator you are.
could mum, but I be a cat and no cat anywhere ever gave anyone a
straight answer, har har."
I just checked the price for an ice maker valve (for a refrigerator). $30
Way too expensive to use appliance parts!
I did a 10 second Google search and that's about what I found too, I'm sure you can do better if you research the valves though. The pressure in this system is very low, the aperature is high though, the biggest problem would be desigining the water holding vessle to avoid water hammer and keep the pressure low, actuating low pressure switches is very easy.
im going to do a small one first with the budget ive got or it could be upto 500$AU i guess. im going to use micro valves and use a microcontroller to control the valves which recieves a bitmap image from the PC. but im confused about the process putting it together. The more technical parts
You can probably make all alpha-numeric characters with 5 valves per character and 1 valve between characters for other graphics. Thus you could start with a few valves initially and scale it up later.
You might try Ebay for cheap solenoid valves.
Zapper
Curmudgeon Elektroniker
--Inside every little problem is a big problem trying to get out.--
To control it from a PC you would need a control module (plug-in or USB controlled) with one addressable output for each solenoid. You may need an amp to drive the solenoids from the controller output, depending upon the controller's current capability.
Then it's just matter of programming the solenoids to open in the sequence desired for a particular graphic or words.
Zapper
With 5x7 high alpha-numeric characters, it looks like you would need the same control program that would be used for a scrolling message display.
Another one: YouTube - Awesome Water Fountain in Japan
Ken
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Sending Pic Data to a serial printer (receipt printer) | 1Steveo | Microcontrollers | 3 | 27th October 2009, 10:45 AM |
| Cycle Timer for waterfall pump | Kurt Schneider | Electronic Projects Design/Ideas/Reviews | 5 | 22nd September 2009, 03:35 AM |
| Printer | shermaine | General Electronics Chat | 8 | 13th September 2009, 05:08 PM |
| Printer -Where to start | bigkim100 | Electronic Projects Design/Ideas/Reviews | 1 | 28th January 2009, 07:42 PM |
| Project improvements? Waterfall flooded my HP printer.. | mramos1 | Electronic Projects Design/Ideas/Reviews | 7 | 8th December 2006, 02:03 PM |
