Hi all i am new to the forum and looks to be a
long time member!!! Lots of good info here...Otherwise heres my project Background I am a 280Z car enthusiast and i am doing a farly difficult convertion. I am placing a LS1 GM Engine into a Datsun 78 280Z. The car is just about done but for a few electronic issues. I created two circuits so far for this car. A PCM Vats Simulator. 5V 40Hz 50% duty cycle square wave --Works Great!! This is the one I need help with. **It is a GM fuel tank sender to Datsun Fuel Guage convertion What I have to work with is a .39V (LOW) to 2.9V (FULL) sending voltage from the sending unit. The Guage uses a 3V (LOW) to 6.5V (FULL) as operation voltage. What i did sofar is designed a circuit that uses two 741 Opamp's. The first is used as a summer and the second as a amplifier. I have simulated it in EWB and seems to work! First Problem!!! I will need to supply the circuit with a +12V to -12V. That would mean i would have to create a AC converter and then convert to DC again....any other ideas??? Will it still work with 12-0V???? Second Problem!!! The guage requires 50mA I dont think the circuit can handled this! My power supply with the regulator really gets hot when I have it direct connected. I was told that I could use a JFET to get this kind of current...I dont know how that works! If a picture would help let me know and i will upload it to my website and post it! Thanks for any help i can get! |
I really need some help with this.
Img of the circuit to give you guys an idea on what i am trying to do. Check it out! ![]() I stated earlier that i needed a +12 to - 12 supply, well i dont mostly just a +9 to -9 supply....well i guess just about anything around there. Any ideas on how i could get that out of a car battery??? The guage requires a little more that 50mA is more to 150mA and dont know if this circuit will beable to handle that kind of load? Does anyone have an idea??? Thanks for any suggestions or maybe a bugger off will work!!! I hate wasting time. |
Hi briguy280z,
Firstly my screen is as wide as these asterisks. ************************************************** *********************** I would be most grateful if you could press return at that width. Have you considered putting a Datsun sender into the tank? I will asume you have considered that, and decided against it. Now, why do you want a negative 12 volt supply for the fuel gauge? Wont it work on a positive supply? I must be missing something here. If the gauge is directional, then cross the wires over. Then it would work on positive volts. As to the difference in sensitivity, i suggest a power transistor such as a 2n3055, and fiddle with the resistors till its right. Regards, John |
Hi briguy280z,
this is the sort of thing i would do for the fuel gauge. Auto electrics do not generally take kindly to complex electronics, the switches etc are usually a bit rough. The electronics in the alternator is usually way over 12 volt breakdown, and probably well damped. A 2N3055 is wellover 12volt rated and should easily handle a few amps before worrying, with a heat sink it would handle 10 Amps easily. They are fairly common and shouldnt be expensive. The arrangement shown is simple, the resistor divider on the base would determine the current through the transistor, the one across the gauge may or may not be needed, to set minimum. Regards, John |
Sorry about the width of the message.
I am pretty high resolution and don't notice how wide my messages are. I fixed it but cant do anything about the pic untill i get home. Otherwise....I needed the +12 to -12 to power the opamp but if your solution works this will make it 200% easier...I completely agree that complex electronics dont work well in automotive applications. Unless you create the right enviroment. To understand this right the first two resisters adjust the multiplier for the voltage to the gauge. The guage does work with current flow there are three connections to the guage Red=Power 12v Black=ground Yellow=Current to ground through the sender But the Camaro sender sends a .3-3v to the ECM which generates a square wave sig to the gm guage. (Unusable) I will work through your solution. Thanks |
briguy280z,
What is the purpose of D4 and D3/R7 in your circuit? Is it to correct nonlinearity in the meter? If not, then it is possible to use a simpler circuit. |
Hi briguy,
I am still curious about why you haven't put a Datsun sender unit in the tank. I assume it is still the Datsun tank, in the vehicle? Regards, John |
Hey John1
Because of the OBDII laws i had to use a Camaro tank in the datsun car. I also needed a high output fuel pump and some EVAP equipment. It was kind of a PITA but it fit without major modifications. That is why i needed a circuit to convert the GM sending unit Float voltage to a datsun Gauge. I have to keep the PCM circuit because it will send a check engine light. Datsun float will not fit into the tank. I messed around with the 2N3055 trying to simulate it and couldnt make it work under 9v. I am going to pull guage out again and put some pots to see if i can make it work. This is nonlinear amplification. Here is some pics if your interested :shock: http://fp2k.redshift.com/briguy280z/ Quote:
resister are to control the max limit and voltage control. In a sense i dont really need them its kind of an overkill. |
Hi briguy,
Had a look over your pics, you have certainly done a lot of work there, looks pretty good. Ive been discussing this with a mechanic friend, and it was put forward that modifying the sender would be more practical. If the float arm is too long shortening it should be ok, the take-up pipe would probably have a gauze over it, that could be shortened a bit and the gauze re-fitted. I am not familiar with either tank myself, but this is the advice i have recieved, that it would be more practical to modify this unit, than to make the electrical/electronic alterations described. Best of luck with it, John |
Hi John
Thanks for your info... I came across a problem when building the circuit that is shown above. I connected the transistor to a slide pot which gave me the min and max Ohm setting for the full and empty positions. I used a cupple pots for the resistor divider and adjusted them to see what kind of gain i can get. I am unable to get a low enough current gain to make it work. I wanted to know if you had any suggestions in fixing this problem. |
A single transistor in a common emitter configuration won't even
start to turn on until the base-emitter voltage reaches about 0.6 - 0.7v, it will never go down to 0.4v :!: If I could suggest a single op-amp circuit... A non-inverting op amp with a gain of 1.4 (ish) with input biassing... If the following resistors are used ... R1 = 2k6 R2 = 9k4 (maybe a 9k1 in series with a 1k preset to set zero) R3 = 4k0 (maybe a 3k3 in series with a 1k preset to set gain) R4 = 1k6 ... the results would be 0.39v in gives 2v6 in to pin 3, 3.6v out of the op-amp, 3v0 at the transistor emitter 2.9v in gives 4v9 in to pin 3, 6.82v out of the op-amp, 6v22 at the transistor emitter so I have got the zero and gain close but not perfect, hence the presets. The transistor should be OK upto 1000mA collector current, or 650mW dissipation, but will require a small heatsink to cope with this. It will be dissipating around half a Watt. R5 is to help limit the dissipation of the transistor and to give some short-circuit protection. You said the gauge takes about 150mA for full-scale? If the resistor is calculated to drop about 3v at full-scale (leaving 2.5v across the transistor); R5 is 20 Ohms, 1Watt
I need a memory upgrade ... My head is full ! |
Thanks mechie
Using a 741 Opamp would be my first guess...? I need a little help with your terminology? R1 = 2k6 (2.6 kOhm)? R2 = 9k4 (maybe a 9k1 in series with a 1k preset to set zero) (9.4 kOhm)? R3 = 4k0 (maybe a 3k3 in series with a 1k preset to set gain) (4.0 kOhm)? 5KOhm Pot so i could adjust the gain if nessary! R4 = 1k6 (1.6 kOhm)? Sounds like a good plan though... I agree on the single transistor idea. I couldnt get anything to register under .7v Thanks for your help Briguy |
A 741 should be good.
Maybe you will need some filtering for the power supply. Resistor values are as you guessed - it is common to use the multiplier in place of the decimal point, it uses one less character and is easier to spot when printed 8) For R3 you could use a 5k pot but that would make setting the gain a bit fiddly, a 3k3 resistor in series with a 1k pot would make setting an exact gain much easier, up to you I guess :wink: For R2 you may want to try the same trick, a 9k1 (9.1k) resistor in series with a 1k pot to make setting zero as easy as possible.
This suggestion was excellent it works the way i wanted it.
I got a problem though! I was an idiot when figuring out what needs to vary and its not the voltage. When i pulled out the guage again i found that there is 3 wires feeding the guage. Black = Ground Red = 12v power Yellow = current to ground through the fuel float In the beginning i though the float varied the voltage going to the guage. I was wrong I can use the circuit you designed by connecting the yellow to ground and varing the power to the guage. Although i would be nice to design it around the original purpose. Current! :roll: What would i have to do to your circuit to change it to adjust the current instead of voltage? When i measure the current with a Pot i get 200mA with 10 ohms High 100mA with 80 ohms Low When measuring the amps they were in pulses so this is the best i can get was the peak pulse at the resistant. I am not sure what to do next i am running into unexplored teritory for me. :?: |
So the gauge needs a current sink (to ground) to work, and
200mA gives a 'FULL' indication 100mA gives an 'EMPTY' indication Are we OK with the float- end of the buiness? You said Quote:
(giving 9v from it to ground) for empty? If I redesign the existing circuit to use the same 0.39v to 2.9v (measured from ground) I think I can create a current sink to achieve this; but as the transistor hfe (current gain) can be anywhere from 63 to 160 you will have to calibrate the amp to suit the actual transistor you have bought. Also, as there is some doubt as to the actual current required for the gauge, the range of calibration will have to allow some space for that. Am I correct in assuming the above ?
