DTMF reciver for mobile
12 Last »
  1. #1
    Sohaib Siddique Sohaib Siddique is offline
    its my 2nd thread i hope my problem is solve
    i want dtmf reciver for nokia mobile
    dtmf reciver easily interfarnce with mobile plz give me dtmf reciver circuit.
    regard
  2. #2
    Boncuk Boncuk is offline
    check out the CM8870. It's a full DTMF decoder with AF input via electret microphone.
    Adjust AF amplification with P1. Pin15 (STD=Delayed Steering Output) goes high when a valid signal (SIGVALID) has been received, and serves as signal to read Q1 to Q4 (A0 to A3).
    Boncuk
    0
  3. Thread Starter #3
    thx i will try kindly breef me wit detail plz
    0
  4. Thread Starter #4
    u mean pin 15 is high when output
    and rn1a is grnd and other also grnd? (RN1B, RN1C and RN1D)
    0
  5. #5
    Pin15 goes high if a valid DTMF-tone combination has been received. RN1 is a four resistor array with a common ground pin meant as pull down resistor for the outputs Q1 through Q4 (A0 .. A3). Q1 .. Q4 are binary coded outputs with Q1 being the LSB.
    Please download the data sheet and study it carefully. It also contains a look up table for binary outputs according to frequencies generated by DTMF devices.
    Other than binary values the CM8870 decodes a 'Zero' being "0000", instead of "1010", provided by a binary coded switch.
    So if you want to create a DTMF-lock don't use 'Zero'.
    Boncuk
    0
  6. Thread Starter #6
    Thx very much
    0
  7. #7
    gagandeep gagandeep is offline
    DTMF help
    EDITED CKT..pnghi ,
    i am interfacing dtmf 8870 with p89v51rd2, Need help with mt8870DE in myanmar-edited-ckt..png circuit attached
    i am not getting desired led outputs by connecting nokia phone
    please help
    RD pin of 8051 to be connected????
    0
  8. #8
    audioguru audioguru is offline
    I am in the West. Most of us Western people played with DTMF about 32 years ago. Unfortunately the internet was not used then so the articles about DTMF are not on the web today. Also cell phones (mobile phones?) were not used then.
    Many printed magazines from the West about 32 years ago talked about DTMF.
    0
  9. #9
    Reloadron Reloadron is offline
    How exactly are you getting the tones to the decoder. The drawing really does not show that part. What exactly happens with the LEDs?
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
  10. #10
    Quote Originally Posted by Reloadron View Post
    Ron
    LEDs connected on o/p of dtmf
    On reset - 0110
    On pressing 1- 1000
    on pressing keys leds glow for some time and again reset (0110)
    even 8051 not responding
    please check code
    org 00h
    mov p1, #0ffh; // Port1 as input port
    mov p2,#00h ; // Port2 as output port
    start:
    mov a, p1;
    cjne a,#0ffh, for1;
    jmp start;
    for1:
    mov a, p1;
    cjne a,#01h, for2 ;
    mov p2,#01h;
    jmp for1;
    for2:
    mov a, p1;
    cjne a,#02h, for1;
    mov p2,#02h;
    jmp for2;
    end
    Thanks alot
    0
12 Last »
DTMF Reciver Problem ghauri Electronic Projects Design/Ideas/Reviews 4 23rd May 2010, 08:26 PM
Please help me with an sony reciver little_alien Electronic Projects Design/Ideas/Reviews 2 30th October 2008, 06:17 PM
Infrared Reciver CommanderKeen Electronic Projects Design/Ideas/Reviews 17 21st April 2006, 09:06 PM
reciver yasiny Microcontrollers 2 14th April 2006, 01:03 PM
dtmf reciver n transmitter abdu General Electronics Chat 0 5th January 2005, 06:07 PM
Page Time: 0.13913 seconds      Memory: 7,657 KB      Queries: 17      Templates: 0
