Hi, I'm an amature trying to make a timer using a 555 cmos in astable mode to light an led at a specific time say 10 hours and then run for around 3 hours and stop. The Vcc should be +6 volts, any help on resistor and cap values would be great as I'm having trouble working out the math. thankyou.
You need to drive a divider chip from your 555. Your question has been asked before, so do a search for previous answers. |
i think that one hour is doable.......so use a 4017....but this way you have 1hour on time and 9 hours off time....
May be in Giga Ohms and capacitor in Farads
T_on = 0.693 * (R1+R2) * C T_off = 0.693 * R2 * C We get R1 = 4.08 M and R2 = 4.6 M This I think is practically impossible. I don't think the circuit will be reliable at all. Well, it can be done using long duration timer IC from EXAR. Its XR22?? along with 555 serving a clock to this IC. I don't remember the number of this IC since I studied it quite long back and have never used it practically. May be some on here knows it.
"There is no way to peace, peace is the way!" |
How about using a 4060, on board clock with RC timing and then binary counting........ timing can be set quite accurately if you use a preset....... or else, a 4047, and 4040 combination......
just a suggestion of course, unless you need to use a 555 8) |
Even that is a good solution.
If more accuracy is required use Crystal Oscillator.
