dc -dc convertor help.
1 2 3 4 Last »
Results 1 to 10 of 38
Reply to Thread
  1. #1
    jorjo
    jorjo is offline
    Default dc -dc convertor help.
    hi every body.
    I'm working around a circuit , but now I have a problem.
    In my circuit outlet there are below constants:
    5VDC ,5mA
    I can't use these parameters foy any purpose becouse they are too low.
    I need a DC/DC convertor and current buffer to drive 24VDC & 250mA relay.
    I have 24 VDC in another positon and can use it.
    pls suggest an IC or circuit.
    thanks.
  2. #2
    Hero999
    Hero999 is offline
    Banned
    You can't convert 5VDC @5mA to 24VDC@250mA because there isn't enough power.
    Change the following:
    R1 = 680R
    T1 = BC337
  3. #3
    jorjo
    jorjo is offline
    what about 24VDC @100mA?
  4. #4
    ronsimpson
    ronsimpson is offline
    ?????You need 24V at 100mA and you don't have any power?????
    A DC/DC converter will not fix this problem.
  5. #5
    Hero999
    Hero999 is offline
    Banned
    Quote Originally Posted by jorjo View Post
    Change the 12V in the circuit to 24VDC.
    As mentioned above, you need a 24VDC supply, which you said you already have in your first post.
  6. #6
    jorjo
    jorjo is offline
    I have 24 VDC from another position in circuit.so I can have enough power .
    Isn't it?
  7. #7
    jorjo
    jorjo is offline
    also unlimited current.
  8. #8
    Hero999
    Hero999 is offline
    Banned
    Please post a schematic.
    You don't need to limit the current, the relay will only draw as much power as it needs.
    If your power supply is only rated to supply 100mA and the relay requires 250mA, then you're out of luck. You either need to get a power supply which can provide 250mA or get a relay which uses less power.
  9. #9
    jorjo
    jorjo is offline
    I draw your recommended circuit in proteus.
    but it didn't work properly.
    where is output?
    answer: collector, I think.
    when input is hi or low collector didn't change,becouse you used inductor in collector.
  10. #10
    rmn_tech
    rmn_tech is offline
    The 'inductor' in the Circuit is your relay coil.
    Read the current through it in proteus.
    I think, therefore I am. Therefore I must be !!! I think ???
1 2 3 4 Last »
Reply to Thread
  1. DC-DC convertor LT1936
    By Zener_Diode in General Electronics Chat
    Latest: 18th February 2010, 05:04 PM
  2. About the DC/DC Convertor
    By kencai in Electronic Projects Design/Ideas/Reviews
    Latest: 16th July 2008, 01:48 AM
  3. Resistance convertor
    By GreenEnvy in Electronic Projects Design/Ideas/Reviews
    Latest: 21st July 2007, 08:10 PM
  4. Flyback Convertor Help
    By moh19814 in Electronic Projects Design/Ideas/Reviews
    Latest: 4th April 2007, 10:35 PM
  5. dc/dc convertor
    By steve england in General Electronics Chat
    Latest: 2nd October 2004, 03:45 PM
