+ Reply to Thread
Page 1 of 9
1 2 3 4 5 ... Last
Results 1 to 15 of 122
Thread: can I hire somebody here?
  1. #1
    joe_rocket Okay
    Join Date
    Jan 2010
    Location
    okla
    Posts
    90
    Unhappy can I hire somebody here?
    I've been reading and building stuff using yenka for a day now and all I have is a headache.
    I am willing to pay somebody to help me build a circuit... if it's not against forum rules.
    The circuit needs to use the tach wire from a GM HEI module
    measure the rate change of the frequency, if the rate change is too great it needs to output a ground signal so I can trip a light or buzzer.....
    If this is the wrong place to ask this can somebody point me to a place where i can hire somebody to help me ....
  2. #2
    Super Moderator bryan1 Excellent bryan1 Excellent bryan1 Excellent bryan1 Excellent bryan1 Excellent bryan1 Excellent bryan1 Excellent bryan1 Excellent
    Join Date
    Aug 2004
    Location
    Adelaide Hills Sth Oz
    Posts
    1,091
    Blog Entries
    4
    Hi Joe,
    I'm a bit far away to help but I recommend you go look at the siliconchip website
    Silicon Chip Electronics Magazine for Hobby Electronics, Computing, Kits and Projects.
    Then go look for some of their vehicle projects, you will be able to view snippets of the articles and find which one would suit you and more than likely you can buy a kit and put it together yourself.
    Go have a look and if you have any more question just sing out I'd be glad to assist.
    Regards Bryan
  3. #3
    joe_rocket Okay
    Join Date
    Jan 2010
    Location
    okla
    Posts
    90
    Went to the link you left, a lot of projects but nothing exactly what I'm needing here. I followed the link to the voltelectronics.com where they had some pretty neat stuff... and i got distracted with the fancy stuff i want, even found something I'm probably going to buy, but for now I need to focus on this current project instead of getting distracted. They did have something close, a "frequency switch" but it only worked by tripping with a set frequency range, where as i need something that trips with a change in frequency rate.... make sense?
    I think I could assemble it if I had a diagram.. maybe. I'd pay for a working diagram
  4. #4
    Dragon Tamer Newbie
    Join Date
    Oct 2009
    Location
    Pennsylvania
    Posts
    318
    i want $5000 for my idea!!! jk, butt it sounds like what you need is PWM controller (maybe, i'll probably get corrected on that)
    -If we knew what we were doing, then it would not be called research.
    Albert Einstein
    -Real men don't use volt meters, they stand in a bucket of salt water and use their bare hands.
    -Everyone brings joy to this site; some when the log on, others when they log off
    -Creation is determined by imagination, accuracy is determined by tolerance, success is determined by effort.
    Vince Reynolds
  5. #5
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    saudi arabia, srilanka
    Posts
    334
    i got your point, you need to alarm when df/dt is above a limit, for what you need alarm? for +ve or -ve gradiant?
    you have to have a frequency to voltage convertor, trhen pass it through a capacitor and have to use one/ two comparators(slope detector) . for +ve rate of change and -ve rate of change. then combine both to get final alarm
  6. #6
    Dragon Tamer Newbie
    Join Date
    Oct 2009
    Location
    Pennsylvania
    Posts
    318
    told you i'd be corrected
    Albert Einstein
    Vince Reynolds
  7. #7
    3v0
    3v0 is offline
    3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent 3v0 Excellent
    Join Date
    Jul 2006
    Location
    USA
    Posts
    6,464
    Blog Entries
    11
    The hardware is easy enough.
    WHy give up on the code you have been writing in Yanka ?
    Post the flow chart and tell us what you can not do with it etc.
    I live in the Oklahoma panhandle.
    BCHS/3v0's Tutorials
  8. #8
    joe_rocket Okay
    Join Date
    Jan 2010
    Location
    okla
    Posts
    90
    i don't know what df/dt is? digital frequency divided by digital time? and also +ve or -ve?
    Yenka ... i have found some circuits i thought I might be able to make work but yenka does not have the chips these circuits call for and many of the online diagrams i find do not do in yenka what they say on the site.
    here is what I know:
    OK, I need to take a tach wire input signal, which is a square wave that grounds an ignition coil (lots of feedback from what I read)
    as the engine revs the frequency increases proportional to RPM, 4 pulses per revolution, up to 5000 revolution per minute, both with the engine accelerating and decelerating.
    on each acceleration i need a circuit that checks and makes sure the engine is not accelerating too fast, I would like this to be simple without using PIC programming (whatever that is>?). and I don't mind paying, but would really prefer a simple circuit that I can learn from.
  9. #9
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,270
    Blog Entries
    2
    What application do you need such a function for?
    I am fairly familiar with the GM HEI systems but I cant come up with a logical reason to need to know how fast an engine changes speed?
    Over rev protection is logical and commonly used but I have not seen a need for rate of change protection or indication?
    There are frequency to voltage converter IC's like the LM2907 that can put out a simple voltage reference in relation to the input frequency and with some basic comparators an simple circuits an all analog device can be fashioned that would give a output for an excessive increase or decrease of RPM's.
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  10. #10
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    In case an output shaft broke wouldn't the engine over rev so fast it would blow before the rpm limit kicked in? Being able to measure the rise in RPM would all you to stop the engine before it even reached it's high RPM limit if the RPM rise was too fast, kind of like short circuit protection on power supplies which measure dI/dT
    straight answer, har har."
  11. #11
    joe_rocket Okay
    Join Date
    Jan 2010
    Location
    okla
    Posts
    90
    Quote Originally Posted by tcmtech View Post
    I don't have the lm2907 in yenka .. but if you can make an all analog device or circuit i'd really appreciate it, as noted, if something breaks it can be used to save the engine.
  12. #12
    Join Date
    Feb 2009
    Location
    Posts
    3,270
    Blog Entries
    2
    In every application I have ever seen the over rev function is what keeps things from flying apart. You dont set the rev limit above the engines designed maximum RPM.
    I have a MSD ignition system on my old Ford 460 engine that has a built in rev limiter I have set at 5000 RPM although the engine itself is capable of holding together to well over 5500.
    When you kill the ignition that generally tends to stop all RPM increases instantly anyway.
  13. #13
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    tcmtech something bothers me about that, if the rotor shaft is accelerating fast enough inertia should keep it going up briefly you can't instantly stop acceleration instantly there has to be some kind of overshoot possibility.
  14. #14
    joe_rocket Okay
    Join Date
    Jan 2010
    Location
    okla
    Posts
    90
    well this sounds easy according to some, I'm sure it depends on your knowledge. Building a 400hp motor is very easy for some, not so much for others.
    I know how to build motors, I don't know how to build electronic circuits...
    So what say you guys? can anybody write me up a schematic for this with less than $20 in parts?
  15. #15
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Ahh, tcm, it suddenly dawned on me cause I'm slow to remember these things sometimes.
    It's called inertial moment, it's how flywheels allow a buffering of energy. Ever seen what happens when a heavy fly wheel is stopped instantly? Generally things tend to explode =) Granted you obviously haven't had problems with it and it may not even be applicible to the original poster, depends entirly on the mass and how fast things are spinning to see if it'd be a problem. But if the load to a motor is suddenly cut and the engine starts accelerating even once the energy supply to that engine is cut it will still have inertial mass that will keep it accelerating. Engine compression will slow it down and it really depends on how fast the engine is accelerating when it his the RPM cutoff as to what'll happen.
    It's kind of like what happens when there's enough joule energy in the wire when a breaker trips, the device will fry anyways.
+ Reply to Thread
Page 1 of 9
1 2 3 4 5 ... Last
  1. Look to hire a programmer
    By Dishtel in forum Micro Controllers
    Latest: 11th January 2010, 03:38 AM
  2. Project builder for hire?
    By tpravata in forum General Electronics Chat
    Latest: 7th October 2008, 10:42 PM
  3. Can I hire a Post Office Box in USA ?
    By aljamri in forum Chit-Chat
    Latest: 28th January 2008, 07:03 PM
  4. Looking to hire someone to design a radio device.
    By yukz71 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st July 2004, 06:06 AM
