+ Reply to Thread
Results 1 to 14 of 14
Thread: little transmitter
  1. #1
    BC548C Newbie
    Join Date
    Jan 2010
    Posts
    5
    Default little transmitter
    I'm new here and I hope I'm in the right forum.
    In the past two weeks I've built some FM transmitter circuits. My aim is to create very simple circuits.
    The schematics are shown in the attachment.
    The coil in the first schematic ist made of jumper wire. Its diameter is about 5 mm, the length is about 7 mm and it has got 4 turns. In the second schematic aren't actually two coils, it's one coil with a tap (I didn't know how to draw this in my schematic porgram). Diameter 5 mm, length 7 mm and 4 turns. The tap is after the third turn.
    The mikrophone in the second schematic is a carbon microphone. In the first schematic the signal of an MP3-Player is fed into the input.
    Unfortunately there are a few problems:
    1.) The first schematic works, but if I go around in my room it has affect on the signal strength. Sometimes there's no signal at all in the radio.
    2.) Where in this circuit it is possible to connect an antenna?
    3.) The second circuit doesn't work. A friend has built this circuit in the past, and it worked. Does anybody see a problem?
    Thank you in anticipation!
    Best regards
    BC548C
    P.S: I'm from Germany and I'm still learning English at my school, so please do not stone me to death if some sentences or words aren't correct ;-)
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,857
    It looks to me that the first circuit exploits a "parasitic" rf-oscillation to make it a transmitter. I cannot figure out what the role of the reverse-biased LED is, unless it is being used a small value capacitor. Gawd only knows where the thing is oscillating. You are likely tuning a harmonic that happens to land in the FM band, so the signal would be very weak.
    On the second one, the coil should be fabricated as a single winding with a tap ~1/3 of the way from the bottom end (autotransformer). If you built it as two separate randomly placed coils, it will not oscillate. Google "Hartley Oscillator".
    Read this current thread in these forums.
    Mike ML.
  3. #3
    BC548C Newbie
    Join Date
    Jan 2010
    Posts
    5
    thanks for your answer. You're right, the barrier layer capacitance of the LED is used as a 10 p capacitor. If this circuit doesn't oscillate between 88 and 108 MHz (you said it's only a harmonic), at which frequency is it approximately oscillating? Is there a solution for this problem without much more components?`
    I said that before. In the second schematic it's drawn as two coils because my programm cannot handle taps.
    I've got this like an autotransformer. There is a picture in the attachment. Is this coil ok?
    What about the other transmitter in the attachment? Better than the first?
    Greetings
    BC548C
  4. #4
    rahul.sadtm Newbie
    Join Date
    Oct 2009
    Location
    india
    Posts
    43
    hey can anyone tell me why we use C7 capacitor (in BC548C's attatchment)????
  5. #5
    BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent BrownOut Excellent
    Join Date
    Jun 2009
    Location
    Huntsville, Alabama USA
    Posts
    2,174
    I have a 1Mhz Hartley that uses two seperate coils and works, though it's a common emitter type.
    Is this coil ok?
    I have a similar transmitter working and the coil is 10 turns of #22 hookup wire wound on a 1/4" diameter. I used a machine screw to wind it on, and since the coils don't touch, no insulation is necessary. Never tried to wind one with the plastic insulation, but that would be interesting.
    It injects a portion of the L/C signal into the transistor emitter, which is needed for sustained oscillations.
    Lions and tigers and bears, OH MY!
  6. #6
    BC548C Newbie
    Join Date
    Jan 2010
    Posts
    5
    Could you send me please details and schmetaics about there transmitters? I think the 1 MHz transmitter could be useful for medium wave...
    Best regards
    BC548C
  7. #7
    Join Date
    Jun 2009
    Location
    Posts
    2,174
    I'll try to make a schematic that I can upload, if I don't forget. If I do forget, then PM me.
  8. #8
    BC548C Newbie
    Join Date
    Jan 2010
    Posts
    5
    Thank you!
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    Quote Originally Posted by rahul.sadtm View Post
    It's the feedback for the oscillator, which runs in common base.
  10. #10
    rahul.sadtm Newbie
    Join Date
    Oct 2009
    Location
    india
    Posts
    43
    thanks Nigel goodwin.
  11. #11
    flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent flat5 Excellent
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    558
    You seem to be building a 100mhz oscillator on a breadboard.
    This is not recommended. Such breadboards add a lot of stray capacitance.
    Just saying :-)
  12. #12
    BC548C Newbie
    Join Date
    Jan 2010
    Posts
    5
    I've found another schematic here: Miniature FM (Voice) Transmitter #2
    The text says construction is non-critical (does that mean it is possible to create the schematic on a bread-board?). But I can't get the circuit working. If I want to solder it on a perfboard, do I have to consider the position of the parts?
    Best regards
    BC548C
  13. #13
    Join Date
    Oct 2008
    Location
    Amsterdam
    Posts
    558
    These circuits are not impressive. The last one especially. Minimum parts count does not improve reliability or performance...if it will work at all.
    Take a look at Audio Guru's proven design for transmitting music to an FM radio.
    You can find it on this forum. Pictures and all :-)
  14. #14
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,859
    I designed my FM tramsmitter to fix problems complained about a "Simple FM Transmitter" that did not work;
    1) I added an RF amplifier to the output so that the power is increased and as a buffer beween the oscillator and the antenna so that the frequency does not change when something moves towards or away from the antenna.
    2) I added a low-dropout voltage regulator so that the oscillator's frequency does not change as the battery runs down, so that the preamp transistor works perfectly when the battery is new or is old and so that the transmitter still works when the battery voltage is very low.
    3) I added pre-emphasis (treble boost) like FM radio stations have so that the sound heard on a normal FM radio (that has de-emphasis) is perfect and not muffled like simple FM transmitters produce.
    But it is illegal because it output power is too high and its range to a sensitive hi-fi or good car radio is over 2km.
+ Reply to Thread
  1. FM Transmitter
    By crivoli in forum Electronic Projects Design/Ideas/Reviews
    Latest: 14th May 2006, 02:35 AM
  2. FM Transmitter
    By juan123 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st November 2004, 07:13 PM
  3. FM Transmitter
    By tussi in forum General Electronics Chat
    Latest: 14th September 2004, 10:25 AM
  4. FM Transmitter
    By tussi in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th September 2004, 10:16 AM
  5. A AM Transmitter...
    By Someone Electro in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th February 2004, 08:30 PM
