+ Reply to Thread
Results 1 to 4 of 4
Thread: Need help with this led driver circuit
  1. #1
    kreston Newbie
    Join Date
    Jul 2009
    Posts
    3
    Default Need help with this led driver circuit
    Hi there. I need some help with this circuit. I want to know if there is a problem with the voltage input.
    You should know lm317 is an adjustable voltage regulator. That makes about 1.25V difference between adj and out pins.
    Anyway, In lm317's datasheet it says maximum voltage difference : 40V
    Does this mean the maximum voltage input is 40v? or what?
    Because there will be a voltage drop because of led so voltage difference will be around 2-3v max.
    If this circuit is problematic,Can you suggest another adjustable voltage regulator that can handle higher voltages and currents?(and cheap also )
  2. #2
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    saudi arabia, srilanka
    Posts
    333
    your configuration is for constant current, the maximum current you can draw at 15V difference between Vin & Vout is 2.2A as per datasheet.
    since the voltage drop will be very less here, it will work comfortably. calculate the resistance value for 1500 mA or little less. R=1.2/I (may vary litle).
    if you see the package getting hot you can provide adiquate heat sink for more discipation.
  3. #3
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,854
    The typical dropout voltage of an LM317 at 1.5A is 2.25V but could be more.
    The 0.8 ohm resistor needs 1.25V.
    So with a 40.0V supply the LEDs can be no more than 36.5V.
  4. #4
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    The LM317 will get very hot. Prepare to use a heat sink. The resistor will also get hot, since it is dissipating 1.0 Watts. It should be rated at 2W if it is to be reliable.
    de KI6RWX
+ Reply to Thread
  1. Low voltage LED driver circuit
    By RQ1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th October 2009, 09:29 PM
  2. Help needed on driver circuit for bi-colour LED
    By vielle568 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th July 2009, 09:50 PM
  3. Why does luxeon led neea a driver circuit??
    By antoniodilen in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th March 2009, 06:20 AM
  4. high powered led driver circuit...
    By bassboi in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th June 2008, 03:23 PM
  5. New driver circuit for 1W LED
    By zachtheterrible in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th November 2005, 11:18 PM
Tags for this Thread
