Trouble with Audio Output Selector Switch
1 2 Last »
Results 1 to 10 of 11
Reply to Thread
  1. #1
    Stalin828
    Stalin828 is offline
    Default Trouble with Audio Output Selector Switch
    Let me preface by saying I am a total noob at this stuff. I work at RadioShack and goof off with it when I am bored at work.
    Anyway, I have a problem with my home computer. I have a soundcard that has 1 input and 1 output. However, going into that 1 input I constantly swap between my XBox360 and my microphone. And the 1 output is witness to a constant battle between my headphones and my speaker.
    So, one day at work I decided to make a selector switch that I could just plug all of my stuff into and flip a couple switches to choose, instead of all the fuss and muss of pulling my computer out every time I needed to make the switch.
    So, what I have is a black box with 2 1/8" TRS jacks on the back. They go to the microphone and headphone jack on my soundcard. On the front of the box is 4 1/8" TRS jacks. All the jacks are the standard open circuit style (when there is nothing plugged in the circuit is open, it is closed by the tip when a device is plugged in). Then I have 2 DPDT switches on the top (one for mic/xbox the other for headphone/speakers obviously).
    It works perfectly, except for one minor annoyance. When using my headphones there is very faint noise on the line. The level of the noise doesn't change if I turn the volume up or down on my computer. The noise stops completely if I unplug the speakers from the box though. I have checked and found no shorts. I suspect that it is caused by the way I wired the circuit.
    The TRS jack has 3 connections, left channel, right channel, ground. Now, on my switch it is DPDT so there are 2 connections per side of the switch. Thinking it wouldn't be a problem I soldered the ground wire from both of the front audio jacks to the ground wire of the rear output audio jack. I suspect this is the cause of the interference.
    Any ideas on the cause of the interference or a way of solving the problem?
  2. #2
    Marseyus
    Marseyus is offline
    Why: The buzzing could be from several things, the first suggestion isn't a shirt, but high impedance.
    Example: You'll probably relate well to this example, i was in a similar situation and i had this happen to me. Before when you've plug the headphones or speakers in and sometimes you make contact with your hand and the metal jack tip on the edge of the plug and you get that annoying BUZZ? I'm sure it's happened to most if not all of us.
    Explanation: Taking the previous example maybe the connections are two close somewhere, or there is too much impedance in the line? I do no believe impedance would increase in volume is why I'm picking that one first.
  3. #3
    audioguru
    audioguru is offline
    The buzz is from radiated mains hum that is picked up by unshielded input cables or picked up by wiring inside the unshielded box.
  4. #4
    Stalin828
    I find it strange that the problem only exists when both things are plugged in.
    When the headphones and speakers are plugged in, I hear the noise on the headphones. The speakers are too low quality to hear any noise. If I am listening to the headphones and then unplug the speakers from the switch, the noise disappears entirely.
  5. #5
    audioguru
    Maybe the wires to the speakers act like antennas and pickup mains hum.
  6. #6
    flat5
    flat5 is offline
    Are the "speakers" amplified speakers with their own power supply?
  7. #7
    Stalin828
    Yes, they are amplified speakers, they use a USB port for power.
  8. #8
    MrDEB
    MrDEB is offline
    try un-pluging the USB port and see if you still get hum.
    I'm with the presumption that its mains hum and the wires are the antenna.
    I wonder if adding a capacitor across the outputs of each would help?
  9. #9
    flat5
    flat5 is offline
    Use a switch that completely isolates the "speaker".
    Break the ground wire too.
  10. #10
    Stalin828
    Unplugging the USB connection for the speakers does make the humming go away.
    I haven't tried on my computer speakers, but when I was building it I tried running it through speakers without the ground wire connected and the sound was unintelligible, flat5. Or do you mean disconnect the ground from the speakers and see if the buzz persists in the headphones? I will try this at work tomorrow.
    Don't know if it matters, but the humming occurs at the same level whether the speakers are powered on or off.
1 2 Last »
Reply to Thread
  1. 4P2T selector switch diagram
    By ke5frf in Electronic Projects Design/Ideas/Reviews
    Latest: 20th November 2009, 12:23 PM
  2. Thermocouple Selector Switch
    By jrz126 in General Electronics Chat
    Latest: 29th April 2009, 03:27 AM
  3. Tactile Switch Trouble
    By Meatmod in General Electronics Chat
    Latest: 24th December 2008, 12:06 AM
  4. Stereo Selector IC (Analog Switch) - Like the old LC7821
    By Speakerguy in Datasheets, Manuals or Parts
    Latest: 19th November 2008, 06:13 PM
  5. 5 Output Up Down Switch (gear selector)
    By Phat in General Electronics Chat
    Latest: 15th April 2008, 08:03 PM
