+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 22
Thread: 20mhz RF circuit help me
  1. #1
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    Hello
    This is the first post in this forum
    I want to make a Circuit to send and receive data
    I want to use 2 Crystal (20mhz)
    Such as those found in games (Games Car)
  2. #2
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    20 MHz or 20 mhz? 20 millihertz isn't a practical radio frequency. 20 MHz is already licensed in most countries.
    de KI6RWX
  3. #3
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    20Mhz
    20miga
  4. #4
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    Function is transfer the sound from place to another
    Distance is 10 meters
    But the important thing is to use the crystal because its very accuracy (20.000Mhz)
    Thank you for mneary your reply
  5. #5
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    There are inexpensive commercial units you can buy that will do what you want 16, why are you trying to build the circuit yourself?
    straight answer, har har."
  6. #6
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Inexpensive commercial units would be legal to use, and a 20MHz transmitter would not.
    de KI6RWX
  7. #7
    EN0
    EN0 is offline
    EN0 Bad
    Join Date
    Jul 2009
    Location
    Outer Space
    Posts
    217
    You would have to have a LONG antenna for that frequency if you want it to be very effective.
    Austin
  8. #8
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    Not necessarily EN, all those clocks you see in the US that advertise they're atomic get their signal from a 5 10 or 15mhz signals from Colorado. They don't have very large antennas.
  9. #9
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    thank you,,
    I want to understand how it works
    And do one
    I have many equipments ,coil, transistors....
    and
    I want to use it
  10. #10
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    Quote Originally Posted by Sceadwian View Post
    why large antenna?????
    in car game (27Mhz) antenna is 20cm
    the Differences is 7 Mhz!!
  11. #11
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    please help me
  12. #12
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    a radio Receiver ???
    any Receiver for any wave ???????
    pleeeeeeeeeeeeez help
  13. #13
    Dragon Tamer Newbie
    Join Date
    Oct 2009
    Location
    Pennsylvania
    Posts
    214
    If I were you then I would try some of these circuits.
    For the inductor values, if you don't get the frequency right then try this website:RADIO CALCULATIONS
    For the Low power fm transmiter:
    When assembling the fm transmitter circuit, make sure the rotor of C3 is connected to the +9V supply. This ensures that there will be minimal frequency disturbance when the screwdriver touches the adjustment shaft. You can use a small piece of non copper-clad circuit board to make a screwdriver – this will not alter the frequency.
    Q1 is a conventional Colpitts oscillator design. The audio signal applied to the base of Q1 causes the frequency to change, as the transistor’s collector current is modulated by the audio. This provides the frequency modulation (FM) that can be received on any standard FM band receiver.
    The inductors are 9.5 turns of 1mm diameter enamelled copper wire. They are close wound on a 3mm diameter former, which is removed after the coils are wound.
    The output is a low power of 100 mW, but for some of you this fm rf transmitter can delivers the desired power for broadcasting on your street or with a proper antenna you can cover a small neighborhood. If you need a power wireless fm transmitter use the above menu, you can find transmitters starting with low fm power up to high power fm transmitters.
    but just a heads up if they catch you using this bandwith then you are in big trouble, and FYI HAM Radio operators are crawling all over this bandwidth, I would try a much higher frequency (500 Mhz) remember that the data tranasfer rate cannot exceed the transmit frequency.
    -If we knew what we were doing, then it would not be called research.
    Albert Einstein
    -Real men don't use volt meters, they stand in a bucket of salt water and use their bare hands.
    -Everyone brings joy to this site; some when the log on, others when they log off
    -Creation is determined by imagination, accuracy is determined by tolerance, success is determined by effort.
    Vince Reynolds
  14. #14
    16mofed84 Newbie
    Join Date
    Nov 2009
    Posts
    11
    thank you but this is transmitter
    I need to Receiver circuit ,thank you
  15. #15
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,565
    Blog Entries
    5
    What sort of range do you expect to get? Why 20MHz what's it for?
    Bill
    Smart Kits build Smart People
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. 20mhz-40mhz sine osilator please help
    By matbymay in forum General Electronics Chat
    Latest: 26th August 2009, 07:09 PM
  2. PIC18F4550 running on 20MHz?
    By MrNobody in forum Micro Controllers
    Latest: 5th February 2009, 11:50 PM
  3. 20Mhz PIC & HD44780-clone
    By ArtemisGoldfish in forum Micro Controllers
    Latest: 7th June 2008, 09:37 AM
  4. 20MHz Oscillator not working correctly
    By imhereithink in forum General Electronics Chat
    Latest: 3rd August 2007, 08:38 AM
  5. is this possible to see 20mhz oscilloscope 1000mhz
    By imgemini in forum Electronic Projects Design/Ideas/Reviews
    Latest: 3rd September 2004, 09:18 AM
Tags for this Thread
