+ Reply to Thread
Results 1 to 6 of 6
Thread: A Sample Timer (Need Help)
  1. #1
    MonteCristo Newbie
    Join Date
    Nov 2009
    Posts
    3
    Hi, i'm new to forum and will be great full if somebody help me with this matter.
    my need is a timer to to the following:
    first the usage environment: a APS connected to home electricity to provide emergency light.
    the need of the time is just when the main electricity gone he will turn on the APS for 5 min, then if the reset button pushed it will continue to run till the electricity come again and so on.
    i don't know who to write them in electronic way, but u get my idea which is to protect the batteries from running empty if there was no body at home and APS left powered on.
    many thanks
  2. #2
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Most backup power supplies have a low-battery lockout.
    de KI6RWX
  3. #3
    MonteCristo Newbie
    Join Date
    Nov 2009
    Posts
    3
    Many Thanks for your reply, i already have a low-battery indicator which stops the APS when battery get empty, but this is my needs, the aim is to save the battery for ex:
    - main power on, APS Charging, no timer triggered
    - Main power OFF, APS starts to work for 5 min and continue working if reset button pressed
    -main power On again, APS Charging, No timer triggered.
    scenario: suppose u are not at home and there is main power, after a while the power goes off, so the APS will start to work without any interrupt till batteries get empty, so if u put a timer triggers this u will save battery life.
    many thanks
  4. #4
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Turn the APS off when away. It won't be charging at that time, but it will keep the charge it received while you were home.
    Otherwise you may have to internally modify the APS, which requires much more electronics than simply making a timer. If your APS has a serial port, you would learn how to communicate with it serially.
    de KI6RWX
  5. #5
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,302
    Just use a switch to interrupt the APS output when not at home. That way the battery won't be used at all at mains failure.
    Boncuk
  6. #6
    MonteCristo Newbie
    Join Date
    Nov 2009
    Posts
    3
    timer help
    thank Boncuk for reply, i know its easy to turn off the APS, what if a u for reason u forget to do this (or have a wife know nothing about these things!!!) ??????... and to get on hard work and modify the APS it will be so expensive !!!, i thought this idea will be sample and powerful (I think) and takes no time to build it and install it... i drew a schema (don't laugh..
    i will remove the APS Power Button and replace it with the time..
    thank again
+ Reply to Thread
  1. Sample Circuits
    By mark_3094 in forum General Electronics Chat
    Latest: 18th March 2009, 07:36 AM
  2. 'C' sample codes
    By poppy2008 in forum Micro Controllers
    Latest: 28th August 2008, 06:24 AM
  3. AT89S51 Timer sample program required?
    By prevravanth in forum Micro Controllers
    Latest: 16th December 2006, 10:51 PM
  4. Where to get sample IC's
    By mysemcon2000 in forum General Electronics Chat
    Latest: 22nd November 2003, 07:46 PM
  5. Sample Regulators
    By Kane2oo2 in forum General Electronics Chat
    Latest: 2nd November 2003, 06:41 PM
Tags for this Thread
