+ Reply to Thread
Results 1 to 7 of 7
Thread: Help designing a simple LED table
  1. #1
    RuSty420 Newbie
    Join Date
    Nov 2009
    Posts
    1
    Hi all, first post here!
    I am a beginner to circuitry and DIY electronics and I had a simple project in mind that is something I can use to both educate myself about electronics and make something crafty!
    I want to make a very simple NON-interactive LED backlit glowing end table / nightstand. The table is going to consist of a wooden frame with 3 isolated chambers, each housing different color LED's, and a glass panel sitting ontop.
    Here is an quick sketch (birds-eye view) of my design:
    3ft(w) x 10in (h)
    The brown frame represents the wood skeleton, the colored squares are the three chambers housing the LED's. The glass panel is the same measurments (3' x 10") and rests directly on top of the panel. In between will be a sheet of rice paper or similar medium to diffuse the light.
    I plan to have 9 LED's in each square, organized by color (red, yellow, green). The three squares will be wired to a simple on off switch and powered from the wall.
    So now, onto the questions:
    • 1. How do I correctly setup the LED circuit so that the LEDs are in groups of 10 with each group linked to the on/off switch?
    • 2. For 27 LED's (9 red, 9 yellow, 9 green) what kind of DC power supply should I use to power from a wall socket?
    Thanks for looking,
    -RuSty
  2. #2
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    saudi arabia, srilanka
    Posts
    275
    make 9 leds in series and grop it as one and 3 such groups. you need a power supply of
    9x1.3V(depends on the led specs, 15V can be used) and a series resistor to limit current for each group.
    the current capacity can be not less than 3 x led rated current, if 20mA is required for one LED (since its in series its same for a group) then need 60mA minimum.
  3. #3
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Why groups of 10?
    de KI6RWX
  4. #4
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    Posts
    275
    he has total 30 LEDs and installed in 3 blocks, so in one time 10 LEDs are switched on, hope thats the reason he mentioned as group of 10.
  5. #5
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Quote Originally Posted by mbarazeen View Post
    As I read it, he has 9 red, 9 yellow, 9 green and wants them in groups of 10.
    Unless he is working on two different designs.
    de KI6RWX
  6. #6
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,302
    Hi mbarazeen,
    only IR-LEDs have a forward voltage of 1.3V. Green, yellow and orange LEDs normally have an Uf of 2.4V, red LEDs are generally 1.8V.
    So for the green and yellow boxes the OP would need a power supply with at least 21.6V output voltage, for the red box 16.2V would suffice, provided the OP wants to use 9LEDs in each box.
    Here is a schematic how to connect the 27LEDs to a power source of 7.5V, rated current output not less than 200mA.
    Boncuk
  7. #7
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    Posts
    275
    :P, yes you are correct its 9 only i made a mistake when commented. also of cause the voltage is fully depends on LEDs specs and i just told it as an example. what you have posted is a good configuration. thanks for correcting me.
    also he can follow the bellow to calculate the value of resistors to be conected in series as follows.
    R= (Vs - N.Vd) / Id where
    Vs- source voltage
    N- number of LED in series
    Vd- rated forword voltage of one LED
    Id - Rated current of the LED
    keep the source voltage always higher than N.Vd,
    when (Vs-N.Vd ) is higher it will give stable brightness over any small variation of the source voltage
+ Reply to Thread
  1. Beer Pong Table With LED Lights
    By sizzox in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th October 2009, 12:46 AM
  2. Motion sensitive led circuit aka led coffee table
    By gregted1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 12th January 2009, 08:13 AM
  3. lookup table made simple
    By jkmadsci in forum Micro Controllers
    Latest: 5th October 2008, 01:39 AM
  4. LED Coffee Table
    By Stellarcore in forum Electronic Projects Design/Ideas/Reviews
    Latest: 30th November 2007, 06:13 PM
  5. Simple Table Read and Table Write for PIC18F452
    By daveboy in forum Micro Controllers
    Latest: 17th July 2003, 09:44 PM
Tags for this Thread
