What is MOV!
1 2 Last »
Results 1 to 10 of 16
Reply to Thread
  1. #1
    Suraj143
    Suraj143 is offline
    Default What is MOV!
    Hi I want to know what is the meaning of MOV.I have seen them on power supplies.What is the purpose of using them?
  2. #2
    mikeReynolds
    mikeReynolds is offline
    The "real" world, for all practical purposes, is seldom more than 24 bits wide.
  3. #3
    Suraj143
    Suraj143 is offline
    OK thanks.
    Let say I have a transformer power supply.
    230VAC/12VAC out.I use a bridge,smoothing cap & a 7805 to regulate & take 5V DC out
    Where is the best place to add a MOV?I'm mounting this power supply to a plastic box.
  4. #4
    Sceadwian
    Sceadwian is offline
    Varistor - Wikipedia, the free encyclopedia
    Looking this information up for yourself before posting is generally a good idea.
    could mum, but I be a cat and no cat anywhere ever gave anyone a
    straight answer, har har."
  5. #5
    Suraj143
    Suraj143 is offline
    It doesn't have any diagram how to connect to a power supply.
  6. #6
    Sceadwian
    If you can't figure out where a MOV might be useful in connecting to a circuit for surge suppression after reading the available information on Google and Wikipedia you have no business working with line voltage.
  7. #7
    mesafloyd
    mesafloyd is offline
    I am curious why you are asking this question… why do you think you need them?
    You’re playing in what could be a dangerous area. You typically put them in three places:
    The + to Common,
    The + to Earth and
    The Common to Earth.
    (Some people just put them only across + to Common)
    Now having said that YOU MUST BE CAREFUL OF THE VALUES YOU SELECT AND THE DISSIPATION YOU ARE ANTICIPATING TO SURPRESS.
    Remember basics here. At 230 VAC = 260v PEAK. So without surges, Your voltage peaks at 262.43V ( 230 x 1.414).
    Hope this puts you in the right direction.
    Floyd
  8. #8
    Suraj143
    Suraj143 is offline
    Thanks Floyd,
    But I thought they were putting to 230V side.I'm thinking like this.
    Live to Earth
    Neutral to Earth.
    Is this correct?
  9. #9
    mesafloyd
    Yes you can omit the one across Live to Neutral if you like.
    That is up to you.
    You should research your needs to decide how much protection you will require. Remember these MOVs are simply to protect your circuit. You could overkill protection needs. Safety is a primary goal and protection of you circuitry is secondary.
    Floyd
  10. #10
    Shax
    Shax is offline
    I've knocked up a drawing to show how I use MOV's and suppression caps.
    All quite simple. The MOV goes across the Live and Neutral, and the caps across Live and Neutral, and also Live to Earth and Neutral to Earth.
    Be careful playing with line voltages, you rarely get a second chance if you do things wrong!!!
    Shax.
    A bus station is where a bus stops...
    A train station is where a train stops...
    On my desk I have a work station...
    Nuff Sed!!!
1 2 Last »
Reply to Thread
  1. How can you check that MOV is damaged?
    By alphadog in Electronic Projects Design/Ideas/Reviews
    Latest: 31st March 2009, 12:55 PM
  2. Varistor (MOV)
    By rainman1 in Electronic Projects Design/Ideas/Reviews
    Latest: 27th March 2009, 01:42 PM
  3. Converting video - .mov to .wmv
    By stevez in Members Lounge
    Latest: 6th February 2008, 07:50 PM
  4. Putting a MOV into my power supply?
    By Chris_P in General Electronics Chat
    Latest: 12th March 2007, 11:45 AM
  5. PIC macro mov reg,lit or mov lit,reg
    By William At MyBlueRoom in Microcontrollers
    Latest: 4th December 2006, 03:32 AM
