+ Reply to Thread
Results 1 to 9 of 9
Thread: 315MHz and 434Mhz Tx-Rx..do they interfere??
  1. #1
    msd
    msd is offline
    msd Newbie
    Join Date
    Nov 2009
    Posts
    16
    I am trying to communicate two wireless nodes having..
    Node1. 434Mhz--Tx..315Mhz Rx..
    Node2. 434Mhz--Rx..315Mhz Tx..
    I have used ht640 and ht648 as encoder decoder for each wireless line(with different addressing)..
    My problem is these two pairs does not work concurrently...they work perfectly when powered alone...but when both are powered together only 434Mhz pair works...I want to communicate to and for at same time...
    Does these pairs interferes????
  2. #2
    ccurtis Okay
    Join Date
    Dec 2008
    Location
    New Jersey
    Posts
    461
    Any frequency of sufficient amplitude to enter a receiver’s front end will reduce system range and can even prevent reception entirely. Such may be the case when a transmitter at one frequency is located too close to a receiver of another frequency.
  3. #3
    ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    You are likely desensitizing your receiver front-end. CCurtis is correct.
  4. #4
    birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,061
    Really? Would explain a problem I had a while back...how do you avoid this problem?
    Mike
    My website: www.ElectroBird.net
  5. #5
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,371
    Quote Originally Posted by birdman0_o View Post
    Don't transmit whilst receiving.
    Apart from that, MUCH higher quality RF modules.
  6. #6
    ccurtis Okay
    Join Date
    Dec 2008
    Location
    New Jersey
    Posts
    461
    One way is to share a single antenna and switch it between tx and rx, switching to tx when transmitting and to rx otherwise. That method precludes full duplex (simultaneous TX and RX) operation. Another way is to put additional bandpass (high Q) filtering at the receiver's front end. Another way is use as high gain and/or high Q (frequency selective) or cross-polarized antennas (one H pol, the other V pol).
  7. #7
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    Quote Originally Posted by ccurtis View Post
    No, sharing an antenna and switching tx and rx is half duplex. The method you just described is not simultaneous, the method the OP is describing is full duplex and is intended to be simultaneous, and requires two seperate and adequately spaced frequencies.
    Using a notch filter would be another way to correct desensitization at the frequency that is causing problems.
    Edit, I'm sorry, I misread your comment when you said "precludes". Dyslexia I suppose.
    You are correct, it does "preclude" full duplex.
    Also, I do not think the application here sounds like simple voice communication...probably wireless computer stuff if I get the OPs drift.
  8. #8
    PatM Newbie
    Join Date
    Apr 2009
    Posts
    93
    Make sure that you are operating legally in whichever country you reside in.
    Some low power transmissions may be legal but most require a proper license to operate.
  9. #9
    msd
    msd is offline
    msd Newbie
    Join Date
    Nov 2009
    Posts
    16
    To all!!
    then I should put aside my efforts to make full duplex...or is it any chances to achieve this??
    one was saying band pass and notch filter...can you elaborate on that...
    and its not voice communication...its simple data communication...(control and feedback)
+ Reply to Thread
  1. On/Off control of an inexpensive 315MHz TX module?
    By blueroomelectronics in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th July 2009, 08:20 AM
  2. MPLAB interfere with MSN messenger?
    By jeremygaughan in forum Micro Controllers
    Latest: 6th August 2008, 06:04 PM
  3. Bandpass filter needed for 434mhz
    By Shax in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st March 2008, 11:14 AM
  4. 315Mhz Receiver
    By VictorPS in forum General Electronics Chat
    Latest: 11th July 2006, 08:32 PM
  5. RF 433 or 315Mhz module antenna problem
    By nikhil arora in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th March 2006, 10:43 AM
Tags for this Thread
