+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: led temperature/humidity addon
  1. #1
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    I have designed and built a thermostat for my incubators. It works awesome. Just recently with help from MikeIM i have incorporated a motor control for the egg turner. My next addition is to add a led humidity sensor displayed in a blue 4 number 7 segment and a temperature display in red 4 number 7 segment led. I want to stress " I DO NOT WANT A LCD DISPLAY" I want led because they are viewable from a distance and i like the colors. I would appreciate any help that you could give me. I also don't have a programmer so advise on one that i should have to program multiple types of chips would also be appreciated.
    I have attached the schematic for what i am currently using.
  2. #2
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    actually i am using a 10m on the r7 for now. I am getting a .3 degree hysteresis but i am also getting a relay chatter. Probably a 4 to 5 click chatter. I am waiting for my new resistor assortment to try out a 9.09m to stop the chatter. If i can get .5 degree variance between cycles without the chatter i will do cartwheels in the front yard.
  3. #3
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    It's a waste of your time posting fuzzy jpegs. We can't read them.
    You just have to tell PAINT you want PNG in the drop down menu on the 'save as' window.
    de KI6RWX
  4. #4
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    I was using a screen shot of eagle. Here is the eagle sch file to view.
  5. #5
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    And here's the screen capture in PNG.
    de KI6RWX
  6. #6
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    That is better. How did you transfer from sch to png?
  7. #7
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Ah, to reduce the relay chatter, R7 should be decreased. This does decrease the precision.
    Maybe it would be more stable if you put a 100uF cap from the pot pin 1 to GND.
    de KI6RWX
  8. #8
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    I could try that. I will build it on the bread tomorrow to see if that will fix it. Problem is that it will work on some boards and not on others.
  9. #9
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Quote Originally Posted by cbiblis View Post
    Screen capture.
    Open Paint.
    ctrl-V, esc
    select desired area
    ctrl-C
    ctrl-N (new document) answer 'no' to save
    ctrl-V, esc
    save-as
    choose directory. choose name.
    just below the name you typed, click in the window that reads JPG, and select PNG.
    de KI6RWX
  10. #10
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    Quote Originally Posted by mneary View Post
    By the way if this pans out i will have to add to your rep with " He's a super genius"
  11. #11
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    I put in a 100uf cap in like you said and it didn't fix the issue. i even dropped the value of the r7 to 4.7m and this one specific thermo continues to chatter. All of my other identical circuits works with the original design without chatter. I did have to drop the r7 on one of them to 6.8m to stop the chatter. 6.8m widens my variance to 1.5 degree differance. I assume i would get a much wider valiance if i was forced to use the 4.7m.
  12. #12
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Is the voltage across ZD1 stable? Variance there could also cause problems, although the sensor circuit is ratiometric and should be immune to most reference changes. Try the 100µF across ZD1.
    de KI6RWX
  13. #13
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    Which side of the zener do i try it on?
  14. #14
    Join Date
    Feb 2007
    Location
    California, 90266
    Posts
    3,526
    Positive to cathode, negative to anode.
    de KI6RWX
  15. #15
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    Are you telling me to piggy back the diode?
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. An algorithm for controlling temperature and humidity of greenhouse and aviculture
    By amindzo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th November 2008, 04:00 PM
  2. Replies: 7
    Latest: 1st September 2008, 11:02 AM
  3. Calibrating temperature in PIC based temperature controller
    By Shohadawy in forum Micro Controllers
    Latest: 23rd February 2008, 10:32 PM
  4. temperature to led
    By robertotrevino in forum Electronic Projects Design/Ideas/Reviews
    Latest: 18th March 2004, 07:54 PM
  5. Controller for lighting, temperature, humidity, etc.
    By Magnus357 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 4th January 2004, 01:10 AM
Tags for this Thread
