+ Reply to Thread
Results 1 to 15 of 15
Thread: 9.7 / 31v DC supply
  1. #1
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    9.7 / 31v DC supply
    Hiya, newbie here.
    I've got an old pen plotter that's missing a supply, so I want to build one. It's strange old thing with a cloverleaf pin power connection, requiring 9.7v DC on one and 31v DC on the other.
    As it's not a 'dual supply' in the usual sense of equal +/-, I'm wondering if there's anything I should be aware of in identifying a design. (The output needn't be more than 1 amp.)
    As the input voltages are both positive, I'd wondered whether I could simply step down the output of a 32V adaptor I scavenged at a flea market, either resistively or with an active circuit.
    Any pointers appreciated.
  2. #2
    ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    Unless the load is pretty consistent you will have a difficult time resistively regulating to 9.7 V, and your resistive component will waste a lot of power. You'll be better off finding a suitable regulator. I would think a 10 V regulator would suffice with a caveat.
    When you say pen plotter, I am taking it you mean, what we refer to in instrumentation, as a chart recorder or integrator. Can you identify the model and manufacturer? Honeywell perhaps? Leeds And Northrup?
    Those supply voltages seem rather odd. Be aware that integrators have signal inputs as well as power inputs. The voltages you mentions seem odd for signal inputs as well, but no more odd than for power supply.
    Or maybe by pen plotter you mean something totally different?
    EDIT: Man, I should Google terms before I respond sometimes. Pen Plotters and chart recorders are similar devices but rather different in purpose. I'll stand back and let someone who knows what they're talking about comment LOL
  3. #3
    microtexan Good microtexan Good
    Join Date
    Mar 2008
    Location
    Texas
    Posts
    348
    Can you give us the make and model of the plotter?
    I totally take back all those times I didn't want to nap when I was younger.
  4. #4
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    It's a Roland DXY1300, as shown below.
    I haven't any schematic / user manuals, so am not sure what the power board is doing.
    I'm guessing the 31v drives the stepper motors.
  5. #5
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    any further ideas?
  6. #6
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,033
    Blog Entries
    2
    Just use a common 32 volt DC power adapter that some of the the HP printers use for the 31 volt part and a second 9 volt power pack for the 9.7 volt part.
    Typical printers and printer power packs are very sloppy on what voltage they actually produce and use. Anything close will typically works.
    My old printer had a 40 volt open circuit on the power pack and pulled down to around 28 volts at times when printing and that never bothered it.
    "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
    "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
    "Your impossibility may just be my day to day routine." -- tcmtech
  7. #7
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    40 volt open circuit? Might have been a switched mode supply, many designs require a load to regulate.
    I'd go with tcmtech's idea dglp, it might be a little awkward having two supplies for the one power connector but it'd work fine. Your biggest issues is going to make sure you a power supply that can give it enough current, and of course make sure you hook the power up to the right pins =) You should be able to trace that from the power connectors on the board though.
    Good luck with that, looks like a solid toy to get to play with.
    straight answer, har har."
  8. #8
    Join Date
    Feb 2009
    Location
    Posts
    3,033
    Blog Entries
    2
    It was an old transformer type hence the big voltage drop at load.
    My last HP printer also runs on 32 volts or there abouts and has a switching supply that stays around 33 - 34 volts with little voltage change regardless of load.
    (I played with it one day to see what it could do.)
  9. #9
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    Yeah, I always keep laptop and printer supplies cause they're usually very nice switch modes, at least from more modern devices.
  10. #10
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    Thanks for those tips. I happen to have that 32v supply - so maybe it will give me some motion...
    As for the pinout, I'm thinking the LM340 gets the 9v side and powers the RAM board. I traced the circuit along the line shown in black through the LM340 to the ribbon connector. Do you reckon I'm right about that?
  11. #11
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    If your traces are good it seems sound to me. Ground is pretty obvious, just try to follow the 32volt line and see where it ends up.
    The LM340 is rated at 1amp maximum regulation current, I'm gonna guess it goes to 5 volts.
    If you used a linear regulator from the 32 volts supply. To drop it down to 9 volts you'd need to dissipate a theroetical maximum of 23 watts of power, that's toasty but not too bad, well within the realm of a well heatsinked linear regulator, but that's wasting TONS of power from the 32V supply which may not even already have enough to drive the steppers alone. I'd definitely use a separate 9V supply for the 9V side. Or a switch mode regulator to buck down to 9V
    Be careful if you use two different power supplies though, switch them on via a power strip at the same time, there's no telling what would happen if it only get 32V with no 9V control power, or vice versa.
  12. #12
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    The other line goes to the C317, and I haven't followed it beyond that. There are a couple of what look lke power diodes in that line, but I can't read their numbers.
  13. #13
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,650
    Blog Entries
    1
    hrmm I dunno then, I found a reference on the net to a C317, it is ALSO a linear regulator. See if you can trace any of the stepper motor leads back to the power source as you said that's pretty much gonna be a no brainer that it's the 32V line they go to.
  14. #14
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,558
    You can guesstimate the current for each supply by looking at the size of the fuses.
  15. #15
    dglp Newbie
    Join Date
    Nov 2009
    Posts
    6
    Result here.
    (Does this board permit video embedding?)
+ Reply to Thread
  1. conversion of pc supply to high power rating supply
    By kamran sadiq in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th July 2009, 08:25 AM
  2. PC Supply -> Variable Power Supply + Function Generator
    By transistance in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd March 2009, 02:16 PM
  3. Techniques... Making a Dual Supply from a Single Supply
    By Ayne in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st February 2009, 03:06 PM
  4. Split rail supply needed from single 12v supply
    By johneaston in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th May 2007, 08:22 AM
  5. Power supply/ current supply design
    By inkedallusion in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th December 2002, 02:10 AM
Tags for this Thread
