+ Reply to Thread
Page 1 of 8
1 2 3 4 5 ... Last
Results 1 to 15 of 111
Thread: Trying to design a super efficiant heater
  1. #1
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    I am tring to design a super efficient heater for my incubators. So far the only idea i have found was a resistor heater found in telescopes. Here is what i have so far.
    I want to run the heater on 120v ac. So if i'm doing this wrong please let me know, or if you know of a more efficient way to heat the incubator please let me know. The incubator is basically 8 cu/ft area heated.
    I propose to use 10@ 18ohm 10w ceramic resistors.
    (I want to use 10w cause there cheap and easy to get.)
    18 x 10 = 180 ohms
    115/180 = 0.64 amps
    0.64a x 115v = 73.6 watts
    73.6/10 =7.36 amp each resistor which is less than 75% of the max
    I was also wondering about a spray head spraying the heater to raise the humidity in the incubator.
  2. #2
    KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent KMoffett Excellent
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,332
    Resistive heaters are all 100% efficient. All power is converted to heat. (until they glow...then some is converter to light ) The iInsulating material on the heater affects heat transfer rate, but it's still all heat. The fastest transfer rate is with open nichrome wire elements. In making you incubator more efficient there are two factors: insulation and circulation. Insulation reduces heat loss, and circulation puts the heat where you need it.
    Ken
  3. #3
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    nichrome wire is hard to come by with the specs i need to make it work. Also the idea behind the resistors is to use the insulation to store the heat to reduce cycle times. Do you agree with my assessment?
  4. #4
    Externet Okay
    Join Date
    Nov 2006
    Location
    Silicon Valley
    Posts
    289
    Ken said it right.
    You cannot make a more efficient heater; you can make a more efficient chamber.
    Disemboweling toasters and many heaters yield nichrome wire. Light bulbs on a dimmer is to consider.
    Any mass added in the heat chamber will reduce cycling; be a piece of lead, a potato, or a cup of water.
    Miguel
    Abolish the deciBel !
  5. #5
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    Here is the thing, correct me if i'm wrong but a ceramic heater it more efficient then a strait nichrome wire due to the storage of heat. I have compared the KWH on a nichrome heater and the KWH on a ceramic heater and the difference was 40% more efficient. This is why i am considering the ceramic resistors instead of the nichrome.
  6. #6
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,529
    Quote Originally Posted by cbiblis View Post
    A Watt is a Watt is a Watt... it matters not Watt the heater is made of
    Mike ML.
  7. #7
    Join Date
    Oct 2007
    Location
    Minneapolis MN USA
    Posts
    1,332
    Can you post links to where you saw these spec's?
    Ken
  8. #8
    dougy83 Good dougy83 Good dougy83 Good
    Join Date
    May 2008
    Location
    Brisbane, Australia
    Posts
    710
    Quote Originally Posted by KMoffett View Post
    So what's the heating efficiency of a heat pump then?
  9. #9
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,372
    Quote Originally Posted by dougy83 View Post
    The better the pump, the lower it will be - the idea is to pump, not to generate heat.
  10. #10
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,302
    The idea of an incubator is achieving a very accurate temperature of 37.5deg/C.
    Using heaters storing heat (like high power ceramic insulator type resistors) you'll get a temperature overshoot every time heating is disabled (accumulative heating). Depending on the incubator size the temperature increase might get as high as 2deg/C over the desired temperature reducing hatch rate.
    Using a microcontroller and software enabling the MCU to look ahaed (tendency) activation of heaters can be interrupted by a using a certain lead time. This lead time will only be valid for a certain temperature difference (between amibient air and incubator air). A better solution is using proportional heater control and probably a long period (1 to 2.5 minutes) integral part.
    I have designed an incubator control circuit controlling heat, humidification and egg turner. After some experiments I kicked out the integral part since proportional control suffices with an accuracy of ±0.2deg/C.
    Using a triac or SSR to switch on and off the heater shouldn't be a problem. There won't be burnt contacts (like using a relay) and switching is done silently no matter how many cycles you apply.
    For comparison look at high quality soldering stations. They cycle like hell and do it for 10 to 15 years without having to replace any part.
    Boncuk
  11. #11
    indulis Newbie
    Join Date
    Jul 2006
    Location
    Just outside of "Beantown"
    Posts
    129
    You might want to consider a PID controller for the heater(s).
  12. #12
    Hayato Excellent Hayato Excellent Hayato Excellent Hayato Excellent Hayato Excellent
    Join Date
    Jun 2006
    Location
    Brasilia, Brazil
    Posts
    595
    Blog Entries
    1
    I think that you are confusing the things up.
    Efficiency is what do you need to spend to get what you want.
    Every heater has an efficiency of 100% or near it, because the whole energy is being converted to heat.
    Remember: P = UČ/i
    Now, with a ceramic casing you are going to have more inertia. It will take long to heat and it will take long to cool. But the ammount of heat energy transfered to the incubator is the same.
  13. #13
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    2,838
    If you look at heat out versus energy in, then a heat pump is always more than 100% efficient.
    Carl
    Curmudgeon Elektroniker
  14. #14
    DSGarcia Okay
    Join Date
    Nov 2006
    Posts
    247
    Deleted by poster (I misspoke).
  15. #15
    cbiblis Newbie
    Join Date
    Jan 2009
    Posts
    161
    Ok then, i will consider what has been said thanks for the input.
+ Reply to Thread
Page 1 of 8
1 2 3 4 5 ... Last
  1. super computer
    By nim369 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th February 2009, 10:57 AM
  2. Heater element controler design any improvements posible???
    By rjvh in forum Electronic Projects Design/Ideas/Reviews
    Latest: 31st May 2008, 06:37 AM
  3. Super capacitors
    By Overclocked in forum General Electronics Chat
    Latest: 7th October 2007, 05:50 AM
  4. Super super noob question
    By hvgap in forum General Electronics Chat
    Latest: 14th January 2007, 12:12 AM
  5. Super capacitors
    By ym2k in forum General Electronics Chat
    Latest: 18th August 2006, 12:53 PM
Tags for this Thread
