+ Reply to Thread
Results 1 to 8 of 8
Thread: Rate of flow of water
  1. #1
    Malvinelly Newbie
    Join Date
    Nov 2009
    Posts
    4
    Default Rate of flow of water
    I want to construct a device that can determine the rate at which water flows in a river at time interval. I need a circuit diagram for these device.
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,709
    Blog Entries
    5
    A paddle wheel with a rotation counter.
    Bill
    Smart Kits build Smart People
  3. #3
    birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent birdman0_o Excellent
    Join Date
    Feb 2009
    Location
    Montreal, Quebec
    Posts
    1,064
    In terms of total volume per second, or just speed?
    Mike
    My website: www.ElectroBird.net
  4. #4
    ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent ke5frf Excellent
    Join Date
    Oct 2009
    Location
    Louisiana
    Posts
    761
    Quote Originally Posted by Malvinelly View Post
    There is no practical, accurate way to measure the flow rate of water in a river that doesn't involve multiple samplings across the width and depth of it, with the width and depth being variable conditions that also must be considered at different stages (i.e. flooding) The flow of a river is not laminar enough for accurate sampling in any one location.
    a paddle/counter will not suffice on its own. River flow is typically measured with v-shaped wiers.
    But if you wanted an electronic method, you might consider hollow tubes placed equidistantly across the river and fixed horizontal to the horizon and WITH the flow of the water so that the mouth of the tube does not restrict the flow. A slight connical shape to the tube would reduce eddies (think aerodynamics). An orriface of known dimensions would be located in the center of the tube, fixed with a flange, to cause a restriction and backpressure on the upstream side. Two ports located on opposing ends of the tube would be fixed with sealed (waterproof) pressure transducers. The differential pressure caused by the restriction would be a SQUARE ROOT FUNCTION of the flow rate, precluding of course that the orriface plate selected was of the appropriate dimensions.
    With knowledge of the SURFACE AREA of the diameter of the tube, the pressure and thus flow of the water passing through the orriface, taken as an average across the river, and knowing the width and depth of that sampling area, a reasonable accurate flow calculation would be made.
    Here is a tutorial on differential pressure flow measurement:
    Differential Pressure Flowmeters
  5. #5
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    saudi arabia, srilanka
    Posts
    335
    due to non linear and turbulant flow its not easy to measure it, but if you can make a spill way if its a small river, then when you bring it in steady flow in and out of the spill arrangement, it can be aproximated to be liner and you need to get velocity profile and cross sectional area of the flow to determine the exact rate....
  6. #6
    Malvinelly Newbie
    Join Date
    Nov 2009
    Posts
    4
    It is possible to also check the amount of run of in the river after rain fall? If yes, with which device(s) and and how. If i can also get the circugt diagram and how i can construct it.
  7. #7
    mbarazeen Newbie
    Join Date
    Aug 2006
    Location
    Posts
    335
    can you give some more explanation about your real project. if you want to measure the rain fall in cettain intervels then you may use different idea for that
  8. #8
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,831
    You have answers here; why was it necessary to post the question in another new thread?
    de KI6RWX
+ Reply to Thread
  1. Water Softener Flow Meter Circuit
    By nyjumpee in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th October 2009, 12:54 AM
  2. Water flow rate???
    By ruzfactor in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th June 2009, 07:03 PM
  3. Help! Conventional Flow Vs Electron Flow
    By electric_n00b in forum General Electronics Chat
    Latest: 27th March 2009, 04:33 AM
  4. Current flow Vs electron flow, which were you taught?
    By Leftyretro in forum General Electronics Chat
    Latest: 13th June 2007, 03:18 PM
  5. Flow Measurement of water
    By vik1501 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 27th December 2003, 06:44 PM
Tags for this Thread
