+ Reply to Thread
Results 1 to 10 of 10
Thread: Help: Does a 40V multiplexer chip exist?
  1. #1
    thedude710 Newbie
    Join Date
    Nov 2009
    Posts
    6
    Default Help: Does a 40V multiplexer chip exist?
    Hello,
    I have an input signal that is a square wave that oscillates at ~170kHz with a low of 0V and a high of 40V. I would like to use a de-multiplexer chip to take this input signal and send it to an output of my choice. Is there any de-multiplexer chips that can do this? It needs to be small and light weight. If not, can anyone think of another way of doing this? Thank in advance.
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,847
    How many outputs? Maybe you could use some 100V MosFETs and build your own.
    Mike ML.
  3. #3
    thedude710 Newbie
    Join Date
    Nov 2009
    Posts
    6
    Hi MikeMI,
    I will end up needing ~20 outputs. I was considering putting a few 4 or 8 channel mux in series to get this number of outputs. I think I actually found a mux that will work for me...
    http://datasheets.maxim-ic.com/en/ds...2-MAX14753.pdf
    What do you think?
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,847
    Can you tolerate the 60Ω ON resistance?
    Mike ML.
  5. #5
    thedude710 Newbie
    Join Date
    Nov 2009
    Posts
    6
    I don't understand what the On resistance is. Does this just mean that there will be a voltage drop across the chip? The current need is only about 10mV so if the resistance across the chip is 60ohms then there will only be a ~1V drop which is fine. The biggest concern I have with this chip is it say that under normal operating conditions the current on any channel shouldn't exceed 5mV but at the top of the data sheet is mentions something about max current being 100mV. I need to pass ~10 to 20mV through a channel. Do you think this will be fine? (The data sheed mentions 5mV per channel in the "applications information" section need the bottom. Your help is greatly appreciated!!!
  6. #6
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,700
    Blog Entries
    5
    What is the chip? What are you trying to build?
    Bill
    Smart Kits build Smart People
  7. #7
    ronsimpson Good ronsimpson Good ronsimpson Good
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    710
    Use relays.
    Use solid state relays.
  8. #8
    thedude710 Newbie
    Join Date
    Nov 2009
    Posts
    6
    Hi Bill,
    The chip I found that hopefully will work is MAX14752. As I mentioned above, my concern is the current passing through the chip. The input and output current will be around 10 to 20mV but there is a paragraph in the data sheet that says:
    "The current flowing through each on-channel of the
    MAX14752/MAX14753 multiplexers must be limited to
    ±5mA for normal operation. If the current exceeds this
    limit, an internal leakage current from that channel to
    VSS appears. Larger input current does not destroy the
    device if the max power dissipation is not exceeded."
    On the top of the data sheet it says the max current for input and output is 100mV though. I am not sure of the difference.
    What I am trying to build is the following:
    I have ~20 very small motors that are powered by a square wave 40V, ~170kHz power supply (actually they are each powered by 2 out of phase square waves but this does not matter for the time being). Only one motor needs to be powered at one time so my idea is to use only one power supply and choose which motor to power by using a multiplexer acting as a de-multiplexer.
  9. #9
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,810
    If your output is 10 to 20mV, this is a lot less than 40V. What is the real signal?
    de KI6RWX
  10. #10
    thedude710 Newbie
    Join Date
    Nov 2009
    Posts
    6
    Whoops, I meant 10 to 20mA. Amps not volts. Thanks
+ Reply to Thread
  1. 40V de-multiplexing chip??
    By thedude710 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th November 2009, 04:28 AM
  2. 20-40V 2-10A DC Power Supply
    By Krumlink in forum Electronic Projects Design/Ideas/Reviews
    Latest: 16th December 2007, 11:00 PM
  3. Analog Multiplexer.. does it exist?
    By ikalogic in forum General Electronics Chat
    Latest: 15th January 2007, 01:23 PM
  4. Halogen dimmer IC chip! Does it exist?
    By RobertRoss in forum Datasheet/Parts Requests
    Latest: 4th October 2004, 12:37 PM
  5. Wireless Temperature Sensor Chip? Does it exist and where?
    By cubdh23 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 1st January 2004, 09:21 AM
Tags for this Thread
