Go Back   Electronic Circuits Projects Diagrams Free > Electronic Content > Electronic Books
Electronic Books Recommended books of interest to any electronic enthusiasts.
Old 8th November 2009, 09:44 PM   #1
Default What programming software do you recommend?
Hi, I have no experience with microcontrollers, haven't got to the subject that covers that yet, but I'm starting by reading tutorials and books about microcontrollers fundamentals, and I've seen that some PIC microcontrollers books are about one specific programming software, which one (s) do you recommend me to learn? I know about MPLAB, visual basic, C (have some experience with it), but which one has been better (in your experience) for your projects?
By the way I'm starting with Microcontrollers fundamental by Steven Barret & Daniel Pack.
Thanks.
"A person who never made a mistake never tried anything new"
Albert Einstein
Karkas is offline
Old 11th November 2009, 02:53 AM   #2
ok well, MPLAB is made by the same company that makes PIC micro controllers, MPLAB uses ASM which is simple but hard to learn. you can get different compilers for MPLAB that enable you to use BASIC, c,c++ and so on.
If you prefer basic to any other language, you can look at PICAXE which are based on PICs but use their own boot loader and are good for beginners.
So for recommenced software, there is C18, a plug in for MPLAB that allows you to program c/c++, designed for 18F series micro controllers and above its free but after 60 days, code optimization gets turned off.
There is cc5x which is free-ish that is also a plugin for MPLAB, it lets you program in c for 16F series microchips and below but have a program size limitation for the free version.
so either way, you will be using MPLAB for most of your PIC related stuff
Cheers
Roman
smartie_on_computer is offline
Old 11th November 2009, 05:35 PM   #3
One quick correction. No C++ on microcontrollers usually (there are a few very expensive compilers.) Just straight C.
Your language choices are C, ASM, or a couple different flavors of BASIC. The development environment you use can be anything really, although there are IDEs written specifically for microcontrollers. (MPLab, Hi-Tech's IDE, etc.)
smanches is offline
Old 12th November 2009, 01:16 AM   #4
I use MPLAB and the C/C++ compilers from SourceBoost which have a free student edition. They also do a Basic compiler but I haven't used it.
Pommie is online now
Old 12th November 2009, 03:53 AM   #5
Ok, thanks to everyone for your replies.
So, if MPLAB is free I guess I can download it directly from the microchip website, haven't checked it yet. You recommend me not to start with ASM? I looked up some information about it, it is another compiler right?
I have to check and learn how to get different compilers for it, it is on the information about MPLAB? or do I need someone to explain how to do it?
Thanks.
Albert Einstein
Karkas is offline
Old 12th November 2009, 04:23 AM   #6
The ASseMbler for PICs comes with MPLAB. I would highly recommend learning PIC assembler if you want an in depth knowledge of PICs. Even if you use a high level language, you'll still need to figure out the peripherals and a prior knowledge of ASM helps. If you choose to use the 18F series of PICs, Microchip has the free C18 compiler available too. For the 24F, 30F and 33F there is the C30 compiler also. Both integrate nicely with MPLAB.
kchriste is offline
Old 12th November 2009, 03:35 PM   #7
I stand corrected.
smanches is offline
Old 13th November 2009, 02:51 AM   #8
Thanks again.
I'll take your word, I will learn ASM. Why is it sometimes called assembler and other times assembly?
Is that or I've got confused?
Albert Einstein
Karkas is offline
Old 13th November 2009, 04:25 AM   #9
It is called assembly language. The assembler is the program which converts the mnemonics to binary code. Sometimes people get it wrong or slip up like I just did.
kchriste is offline
Old 14th November 2009, 02:09 AM   #10
Thank you very much. I'll keep it in mind.
Albert Einstein
Karkas is offline
programming, recommend, software
Whats your favorite programming software GRC Micro Controllers 6 30th November 2007 10:54 AM
Progpic2 Programming software david miles Micro Controllers 3 25th October 2006 04:07 PM
Pic Programming software grrr_arrghh General Electronics Chat 7 29th August 2004 08:29 PM
programming flowchart software? RGBrainbow Micro Controllers 0 9th August 2004 12:17 AM
looking for programming software.... Zener_Diode Micro Controllers 9 17th March 2004 07:21 AM
