| Electronic Books Recommended books of interest to any electronic enthusiasts. |
Do-It-Yourself a PICkit2 (Step by step guide) ![]() ![]() System attachment malfunction. A pdf will be loaded by Forum controller.
__________________ F.N. Last edited by Funny NYPD; 17th April 2008 at 05:07 PM. | |
Schematic is available here: http://www.auelectronics.com/Hardware-CB0703.htm
__________________ F.N. | |
wow, this is interesting
Oh that is too hard to build with SMD parts. Here is another good one. http://209.85.171.104/translate_c?hl...GVDVG8gmZBwKbA | |
when people can handle through-hole parts, most likely they will handle the SMD parts much easier.
| | #6 |
many times i write a particular program for a bot.. usually a line tracer.. but many times it doesn't work... any ideas why? how to write the best programs? | |
| | #7 |
First you are hijacking a thread. Your post does not have anything to do with this thread. It could be that you need to learn more about programming or that you need to learn more about the control methods you are using or trying to use. Hang around here long enough and read what others post. Post specific questions. In time you will get where you want to go.
__________________ Please post questions to the forums. PM's are for personal communication. BCHS/3v0's Tutorials Junebug USB PIC programmer kit., USB Bit Whacker, The 15 Minute Printed Circuit Board! (+drill time) | |
| | #8 |
This is all the necessary tools you need to handle the SMD components: Au Group Electronics: What tools do I need for soldering components to PCB? And here is how to identify the SMD pin numbers: Au Group Electronics: How to identify the pin number on SMD packages?
| | #9 |
A blog edition of step by step guide (with better photo resolution): Au Group Electronics: Step by Step Assembly Guide for CB0703 (PICkit 2)
| doityourself, guide, pickit2, step |
| connecting two telephones..step by step question.. | waqar | General Electronics Chat | 4 | 27th February 2009 10:17 PM |
| Motor controller | Totally blank | Electronic Projects Design/Ideas/Reviews | 9 | 16th January 2008 02:12 PM |
| Help needed ASM to HEX with MPLAB | Virus | Micro Controllers | 39 | 26th December 2007 04:30 PM |
| step motors? | mr.engineering | Robotics Chat | 8 | 27th December 2006 03:59 AM |
| Need a little help with my project (Step motor driver). | Ckramer | Electronic Projects Design/Ideas/Reviews | 4 | 26th April 2006 11:59 PM |
