Have a look at Untitled Document
Google: MPPT with ATmega
ken![]()
The problem is very little people know what MPPT stand for especially the T. Out of all, over 200 documents not one of the authors know that the T is for tracking the sun, in other words a MPPT system is to make the solar panel to track the sun and the only way to do it is by using a Micro Controller, I recommend a PIC MCU.
If your looking for a design idea, there is a relatively easy way to do it. Place 4 solar cells (circular, cut in 4) at the bottom of a tube and condition the output of each of the cells (I to V) converter. Rectangular cells should work too. When the light is maximized in the tube, each cell will have the same current.
Now you have to figure out which way to move the motors and you need some algorithm that avoids unnecessary movement due to clouds.
Not true at all. Look Here;
http://www.redrok.com/electron.htm
This is vary old thread If you are looking for help you should have started a new one.
Only dwarves know what the T stands for?
Err... no. The tracking in MPPT (maximum power point tracking) refers to tracking the maximum power point of the panel; not the position of the sun. There is a reason so many authors disagree with you.
There is >1 way.
https://sites.google.com/site/pk2devicefileeditor/
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Solar tracking System for solar cells | bogdanfirst | Electronic Projects Design/Ideas/Reviews | 27 | 23rd October 2011, 06:16 AM |
| MPPT Code in Picbasic | kalaman | Microcontrollers | 2 | 5th September 2010, 07:40 PM |
| RFC Solar Cgarge Controller | MrUmunhum | General Electronics Chat | 8 | 25th April 2009, 04:36 PM |
| Solar Inverter and Solar Tracker | gtoluyemi | Members Lounge | 1 | 15th April 2008, 03:51 AM |
| Light Controller or rather Electrical Outlet Controller | mammanoti | Electronic Projects Design/Ideas/Reviews | 1 | 11th January 2003, 03:09 AM |
