They are called FPC (Flexible Printed Circuit) connectors, Newark do a good range in the USA.
Hi All,
I'm having trouble finding the ribbon cable connector I'm looking for. It's a board mount ribbon cable connector either thru-hole or SMT which is basically the connector I'm showing in the picture I have attached. Essentially you have a bare ribbon cable where you insert it into the connector and then there are clips on each side which secure the ribbon cable and "clamp" it into the conn.
Does anyone know what style conn this is? Or do they have any info. for me?
Thanks.
thanks!!
Looking into these I can't find a connector which will be able to terminate to the flat ribbon cable and then be able to plug into a board mount connector. Looks like I need to call some vendors. Anyone even do what I"m trying to do here?
You want the flexible ribbon to plug into a connector which then as to plug into a printed circuit board mounted connector? Do I understand you correctly?
Digikey has them. You will absolutely need the pitch (e.g. 0.5mm, 1mm, etc) and the number of conductors.
The other pice of info you will need is what side the contacts are on. (e.g. top or bottom). I can see that yours is right angle SMT.
Here is a ZIF (Zero Insertion Force) version: http://www.electro-tech-online.com/c.../e58606137.pdf
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| 20 pin flex cable connector 0.50 mm (.020") pitch botto | jandirks | Datasheets, Manuals or Parts | 1 | 3rd June 2004, 12:57 PM |
| ribbon cable question | kekek | General Electronics Chat | 4 | 19th January 2004, 03:10 PM |
| Taping into painted ribbon with solder-abl ribbon cable | Manicmechnic | Electronic Projects Design/Ideas/Reviews | 4 | 16th January 2004, 04:27 PM |
| Treadmill 16pin female connector for painted ribbon cable. | Manicmechnic | Datasheets, Manuals or Parts | 15 | 15th September 2003, 04:02 AM |
| ribbon cable extension? | catfish | General Electronics Chat | 5 | 24th March 2003, 07:39 AM |
