Old 31st October 2009, 10:34 PM   #1
Default Capacitor Identification
I have a small ceramic or tantalum capacitor. On one side it is marked:
102
AMJ
On the other side it is marked:
103
E1M
Any idea what these codes mean? They don't seem to match any of the coding schemes I've found so far. Thanks.
fordo is offline
Old 1st November 2009, 12:05 AM   #2
Multiplier used on Capacitor Marking Code
Third Figure Multiplier
0- 1
1- 10
2- 100
3- 1000
4- 10 000
5- 100 000
You have a 102 and 103 marking, maybe someone can make heads or tails of the AMJ & E1M
Mike2545
Mike2545 is offline
Old 1st November 2009, 03:05 AM   #3
Are you sure it's not just a printing mishap like the ink wasn't fully applied to the 2 side? Take a look at them under magnification, or post images if you're able. Please for the love of my sanity if you are able to post images, make sure they're fully in focus. 9 out of 10 images I see posted here are badly out of focus in the subject areas field of view.
straight answer, har har."
Sceadwian is offline
Old 1st November 2009, 03:51 PM   #4
The cap(s) is pretty small, about 1/8" x 3/16" radial leaded. I actually put the cap(s) under a low power microscope and there is no doubt about the codes. I know this is puzzling because of the "102" on one side and the "103" on the other side. Also, to further confuse things I haven't been able to locate any info on the E1M or AMJ codes. Finally, I have a tape strip of about 20 of these caps and read the same info on all of the ones I looked at under the microscope (about 5 at random).
If I had a capacitance meter (are inexpensive meters able to read small values like these probably are accurately?), I would probably be able to determine whether they are 0.01µF or 0.001µF and just chalk off the rest of the codes as one of those things I'll never know.
I guess I was hoping someone may have run across a code list that I haven't.
Thanks again.
fordo is offline
Old 3rd November 2009, 08:59 AM   #5
You can test with a (low voltage) source of 60Hz, and a reasonably high impedance meter. Let's assume you're only distinguishing between 0.01µF and 0.001µF, and don't need an accurate measurement.
At 60 Hz, 0.01µF has a reactance of 265kΩ. If you place it in series with a 220kΩ resistor, the two will have a similar voltage drop. (Total won't equal the input voltage; the capacitor is reactive, not resistive.)
If it's 0.001µF, the voltage across the resistor will be about 1/10 of the test voltage.
de KI6RWX
mneary is offline
capacitor, identification
transistor identification kdavidtt General Electronics Chat 2 17th March 2009 03:31 AM
capacitor identification wkman Datasheet/Parts Requests 11 17th October 2008 03:12 PM
IC Identification johnsmith123 General Electronics Chat 4 14th October 2008 02:32 AM
LCD Identification? johnl69 General Electronics Chat 10 20th April 2008 11:27 PM
Component identification? codan General Electronics Chat 3 6th April 2008 08:24 AM
