Old 27th October 2009, 11:55 PM   #1
Default 20 Pin JTAG Header. Edge mounted?
Hello,
I am trying to find a part similar to that used on the Amontec JTAGKey tiny:
Amontec JTAGkey-Tiny : Tiny USB to JTAG cable for ARM via sdk4arm - YAGARTO - OpenOCD
Its the 20 way edge mounted 0.1" female header that I am trying to find a supplier for. A right angle part is not going to be suitable.
If you supply them I am looking to buy 500 to 1000 parts.
Kind Regards
Iain
HotSolder is offline
Old 31st October 2009, 04:01 AM   #2
If your PCB material is thick enough, you can use a straight through hole connector as edge mounted. I've seen people do this before. Half of the pins on one side of the board, other half on the other side.
Mark Higgins
DirtyLude is offline
Old 31st October 2009, 04:58 PM   #3
I know what you mean, its the same shape as a polarised IDC header:
http://www.pimfg.com/products_large/1200-020-25.gif
But it has pins like a standard PCB TH female header. I used one for a DIY USB blaster.
As dirtylude said, its just mounted as end launch, which is often done with 2.54mm double headers. If you do'nt require polarisation, then a standard 2x10 female header fomr Rapid will do just fine. However, if you're after one thats exactly like an IDC cable mounted socket, with centre tab, then a quick search on Farnell, and I got these:
3M|8520-4500PL|SOCKET, PCB, 20WAY | Farnell United Kingdom
As you're in the UK (I'm a fan of your shop btw) I would highly recommend Toby Electronics for connectors. They're reliable, you can order small or massive quantities, and they have literally everything.
I believe you're after these:
Toby Electronics: 2.54mm Pitch Straight DIL PCB Sockets with Bump
Specifically B06d-20-AGAA1-G
Great price too.
Good luck!
Scott.
Inconsistency is the key to flexibility!
Blueteeth is offline
edge, header, jtag, mounted, pin
Female Pin Header AtomSoft Datasheet/Parts Requests 6 1st November 2008 04:13 PM
Need help with header pin mistake kittydog42 Electronic Projects Design/Ideas/Reviews 5 19th May 2007 06:55 AM
Header pin jumper wires. Sceadwian General Electronics Chat 23 21st February 2007 10:58 PM
jtag emulator... amr_electron Electronic Projects Design/Ideas/Reviews 2 26th May 2006 03:25 AM
Breadboard and a 14 pin dual header kcn General Electronics Chat 4 19th March 2005 04:40 AM
