I need to find the schematics for a really old Century mfg. in St. Louis, 1 phase, 5 hp motor. Cat. 6-30036-01. Where do I find that kind of info?
I should not think there is a schematic, ever. There will be a connection diagram. Have you found out what sort of motor. Does it run with a capacitor all the time = split phase. Does it have a centrifugal switch on the shaft, which switches out an extra winding as the motor speeds up. I assume it is a proper shunt wound motor, and not a series motor as in a washing machine. If this all sounds puzzling, try a book from your library. I have one on model engineering Workshop Practice "electric motors" which is helpful, Argus Books, ISBN 0 85242 914 2. Difficult to get in UK, as it is so specialist. Else your local electric motor rewinding or supply firm may well be patient enough to help, and let you look at the installation instructions for a motor he has in stock.
Maybe this will help....
capacitor start motor wiring diagram - Google Images
Eccentric millionaire financed by 'er indoors
They usually print it on the label. Century merged with A.O. Smith I believe
Compressor Motor,5HP,3450,230V,1 Ph,56HZ - Air Compressor Motors - Definite Purpose Motors - Motors : Grainger Industrial Supply
