+ Reply to Thread
Results 1 to 10 of 10
Thread: 300 VDC motor-Available?
  1. #1
    Bill_activist Newbie
    Join Date
    Mar 2005
    Location
    San Jose, CA
    Posts
    4
    Motor Experts,
    Could someone tell me where I could buy a small electric motor that
    will run off 300V DC? It could be either brushless or with brushes,
    one hp. RPM could be 2,000 to 8000 rpm.
    I'm with a small company that is making our first electric car. We
    have a 2001 Honda Civic, have removed the gas motor and will be
    putting in an AC motor, controller, lithium-ion batteries and other
    electronics.
    We need a DC motor to run the air conditioner. Our battery pack is 96
    cells at 3.2 V each, so our battery pack will be 308 V. We have to
    have high voltage, in order to provide enough power to the AC motor.
    We can't run it off 12V, because it would take too much current from
    our DC/DC converter.
    Does anyone know a company or a brand that sells a small, electric,
    off-the-shelf, DC motor, along with the controller, that is powered by
    300V DC? Is such a thing available?
    Thank you,
    Bill
    eeVee Motors
  2. #2
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,033
    Blog Entries
    2
    A standard VFD unit with a single phase 208 -240 AC input would work in your situation. Then all you would need is a standard three phase motor with the common 208 - 230 / 460 volt input ratings.
    Check out eBay. I have bought several of them with a 200 -240 volt AC single phase input and up to 3 hp output capacity. Most of them convert the AC into DC and everything internal is driven off the internal line sourced DC system. Setting one up to use a DC input is simple.
    A good used unit goes for around $50 - $100.
    Plus you would have your speed, reversing, and often regenerative breaking capabilities all ready built in. One potentiometer and one switch for speed and direction control.
    "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
    "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
    "Your impossibility may just be my day to day routine." -- tcmtech
  3. #3
    Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent Papabravo Excellent
    Join Date
    Mar 2006
    Location
    Michigan, USA (GMT-5)
    Posts
    2,892
    The last time I saw a 300V DC motor it was driving the ball screw on the 7-ton spindle of a machine tool. Small and cheap don't seem to go hand in hand with such a motor.
    We never have time to do it right; but we always have time to do it over.
  4. #4
    Join Date
    Mar 2005
    Location
    San Jose, CA
    Posts
    4
    Re: 300 VDC motor-Available?
    TMC Tech,
    Thank you very much for giving me this answer. However, I don't completely understand it. Would you be willing to help me understand it better?
    The VFD is the controller, right? (not the motor)
    The specs for a VFD says it works for 208 to 240 AC input. However, you are saying that you can actually connect DC voltage to a VFD? I can connect 300 V DC to a VFD controller (with specs that say AC) and it will work? Am I describing that correctly?
    Then I would buy an AC motor, 3 phase (208/230/460 AC input) and use the VFD to control the AC motor.
    Am i describing that correctly?
    For my usage, i would like to buy a new motor and new VFD controller. Do you have a suggestion for brand name and/or company where I could buy a new motor and VFD controller?
    thank you very much for your help,
    Bill
  5. #5
    Join Date
    Feb 2009
    Location
    Posts
    3,033
    Blog Entries
    2
    VFD stands for Variable Frequency Drive. Just do an on-line search for dealers. They are a common device. Same with a 3 phase motor.
    Most VFD units take the single or three phase AC input and rectify it to DC. All of the internal power is derived from that DC source. By just feeding DC into two of the three power input wires they will work normally off of a battery system.
    However if you tie the battery into the DC side of the rectifiers the dynamic breaking functions can allow for a regenerative breaking effect also.
    The DC input capacity is not usually referred to on the manufacturers specs sheets though.
    Here are the manuals for three units I have worked with that were able to be set up for DC input without modifications.
  6. #6
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    1,993
    I'm not saying Tcm is wrong it'll work I have Four controllers like what he is talking about there bigger then the motor LOL
    I would like to no what dose that have to do with air conditioner It doesn't need any braking. What he talking about is not that easy to do. And your not going to find any motors in the 300 volt range
    You would be better off tapping your supply at say 90 to 120 volts and using that for
    a 90 to 120 volt Dc motor at 30 amps or less Look here
    Baldordirect, your home for Baldor Motors & Drives : DC Motors
    Sale Price $1,110.75 lol
    Burt
  7. #7
    Join Date
    Feb 2009
    Location
    Posts
    3,033
    Blog Entries
    2
    Sorry I missed the compressor drive system part. Regen not needed.
    A 300 volt battery is very close to the rectified peak voltage of a 208 three phase line/ 208 x 1.414 = 294 volts.
    Therefore a VFD running a 208 volt rated AC three phase motor gives him an off the shelf variable speed motor compatible with a 300 volt DC source.
    He could also skip the motor to compressor connection and just use a stock three phase commercial air conditioner compressor. The cooling capacity of a car is very small (4000 - 8000 BTU) and an electrically driven compressor that small is about the size of a standard automotive compressor any way. Just use one thats rated for what ever type of freon your vehicle is going to be set up for. That would gain some added system efficiency as well!
  8. #8
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    1,993
    That would have my vote. That would be easier to put together and way cheaper. And no loss with belts or hard to make adapters
    Burt
  9. #9
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    11,826
    What's the maximum battery voltage?
    Make sure it's under the AC voltage of the VFD ×√2, for example if it's rated to a maximum of 250V the maximum DC voltage you can power if off is 353V.
    if I know the answer.
  10. #10
    leitmotif Newbie
    Join Date
    Jul 2009
    Posts
    4
    DC motors
    Quote Originally Posted by Bill_activist View Post
    Motor Experts,
    electronics.
    Thank you,
    Bill
    eeVee Motors
    Baldor and other major motor mfrs have new DC motors -- Grainger also only up to 180V.
    To save on some bucks you may have to go surplus.
    http://www.tdigrp.com/products
    You can as already said drive the compressor or whatever with another AC motor and another VFD.
    OTHER QUESTIONS
    REPLY Yes
    REPLY Yes you are basically correct the DC bus voltage is 1.4 x input AC ie 230 so about 325 VDC. The magic term in this application is DC bus share.
    REPLY Yes
    REPLY any name brand will do Allen Bradley Hitachi SJ 300 etc. I intend to retrofit a 56 Chev pickup with 50 HP 3 phase and will use Hitachi SJ 300
    Dan Bentler
    Seattle
+ Reply to Thread
  1. Stepper Motor : XEROX XC 830 MOTOR 55SPM25D5E
    By abuza8nuqina in forum Datasheet/Parts Requests
    Latest: 10th April 2009, 06:38 AM
  2. want to convert floppy's motor as simple 6V DC motor
    By mamun2a in forum General Electronics Chat
    Latest: 19th December 2008, 04:22 PM
  3. DC motor drive of 180V DC/2A ie half HP motor
    By jayaprakashreddy y in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th October 2008, 04:39 PM
  4. DC motor, Servo Motor or Step Motor ?
    By wcz in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th June 2005, 02:41 PM
  5. Motor Characteristics Graph + controlling motor
    By lil'gal in forum Robotics Chat
    Latest: 29th September 2004, 01:30 PM
Tags for this Thread
